Hi,DIYer:
I know naim nap90 is the most smaller amp in the NAP series...
I very interesting in it's schematics,seaching for a long time but could find nothings...
so,I need you help!if you have NAP90 or NAP110's schematics,please post and show it to me..
thank you so much!
WINCO
here is nap135's inner topology:
Expensive box
That's one reason why i never got hooked by the marketing hype of naim equipment. As good as it is you just end up with a very expensive box ! There's better and cheaper equipment out there and they use Audio Mosfets....
I once met the late Julian ( Mr Naim himself ) at a hifi show in London around 1987 when i was in my late teen's. He was an inspiring person, had time for everone . Verygood at marketing as i remember....
Just my 2 cent's
Just my 2 cent's
Re: Hi buddy
ah,Yes!both are good horse!
thank you for your help!
I don't have NAP135's schematics before...
the nap90 or nap110 maybe are too old and hard to find...???
thanks Workhorse again!
regards!
WINCO
here is NAIM NAP140's schematics:
:edit: Link to copyright graphic removed.
Workhorse said:Hi darkhorse
I really like your ID.
Here is a schematic of Naim135 amplifiers, hope you find it helpful
kanwar
regards!
WINCO
Naim is famous firm, with many fans. Something is wrong
I've reached the same conclusion more than 20 years ago. Something is wrong with the fans' hearing ot they simply don't care about the finer aspects and are more impressed with the big picture. Btw, the coupling caps are tantalums!
pinkmouse said:
Please don't post copyright information on the board. You can link to the original site, but don't cut and paste to posts here please.
OK,pinkmouse:
I don't know the picture is protected by copyright!sorry to what I have done!
here is naim nap140' schematics link:
http://www.cndiyclub.com/bbs/dispbbs.asp?boardID=3&replyID=17321&ID=41&skin=1
tmblack said:The NAIM 135 sure is unimpressive. No emitter degenerating resistors on the LTP, no complementary output transistors, .22 resistor instead of coil, risetime capacitors, ugh.
I've seen better amateur designs.
Tom
hi ,Mr.Tom:
many famous amplifier's circuit is so classical topology...and something isn't "HI-FI" from today's modern conception.
the biggest impression to me is QUAD405,I really hate it's circuit
toppology,using many un"HI-FI" things...but it's sound is so humanistic(flesh and blood),...I am so admire QUAD405's designer,they let machine recur the scene and feeling...
upon the word is why I am interested in the classic amp circuit,once you own the machine to hear the song "yesterday once more",I think you will enmeshed the times of the song!
regards
WINCO
tmblack said:I'd like to see the NAP250 schematics?
Tom
OK!here is :
http://www.cndiyclub.com/bbs/dispbbs.asp?boardID=3&replyID=19360&ID=489&skin=1
pinkmouse said:Thanks Darkhorse
The rule is simple, if an image shows a Copyright or C mark anywhere, then diyAudio could get closed down if that image is shown without the authors permission, so we have to remove it.
that's alright!
I don't know the nap90 schematics where is,I am afraid that the schematics have been lost!
from the outlook of the naim nap90,so simple structure...
I don't understand the big deal with the NAP 90 schematics.If you can find the 110, 140, 180 it should be very close because it is the same circuit with higher voltages and power output.The 250 has regulated PS.You could also get some pretty good Naim clone kits from Avondale audio.
However having owned Naim 110,180,250 I still prefer a good gainclone over them, a Pass Aleph design or a good valve set amp.
The 'NAP140' circuit on the first Chinese link is actually the Avondale Audio NCC200. FWIW.
http://www.users.zetnet.co.uk/avondale/
Why can't you trace out the NAP90 circuit? If you want to 'clone' then it's not the right place to start. Try Avondale or the Neil McBride clones, http://www.neilmcbride.co.uk/jknamps.html
Paul
Paul
- Naim NAP90 amp schematics...
