hi everybody!
is it possible to make an amp with output bjts never seitching off by a current source at its base? This one simulates well, with overbiasing like 350-500mA neither of power bjts switches off. But is it real in terms of: equal and known beta, thermal stability..... and so on? I think componets selection would be crucial, maybe MJE21193/4 ? any comments welcome!!!! best regards |
#2 |
It's possible, but from your schematic it looks like all the current is being pushed directly into the bases of the output transistors. That will make it totally dependant on their hfe and thus unworkable in real life.
What you want to do is control the Vbe of each transistor individually. In your circuit you could accomplish that by removing C7 and splitting R50 and connecting the midpoint to the output. Then a fixed current through the now two resistors will enforce a minimum Vbe and thus a minimum current.
https://mrevil.asvachin.eu/ |
#3 |
This concept is right provided linear enough output devices, but note that the drivers are working in class B
#4 | |
Thanks |
#5 |
diyAudio Moderator Emeritus
Can you trick the cct more upstream, like around Q54-55? Maybe a resistor there to the rails from bases gives the same effect?
#6 |
The one and only
You can reduce this trick to the switching of a pair of
small high speed diodes, but you'll have to go elsewhere to have no switching elements in the gain path. And why bother? Get a nice efficient driver with a big magnet and drive the hell out of it with 10 watts of Class A. |
#7 |
darkfenriz,
I don't think this will work. You're just pulling the drivers in reverse. And maybe the drivers are better in switching than the output transistors, but still... Something completely different: I noticed that you have added a capacitor to your current sources, probably for decoupling, but that is not what they will do. In this way you just increase the noise of the current source and add power supply noise to the output. This current source is working with feedback and the capacitor is removing the AC feedback path, making the current very sensitive to power supply noise. Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#8 |
You may want to check a design I proposed in case you have not.
It could easily be adapted to bjt's in EF configuration, main advantage is feedback loop that stabilizes quiescent current independently of device and temperature variations. If you have trouble figuring out how to adapt, let me know, see if can help. Rodolfo |
#9 | |
darkfenriz! do you try to do it?
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#10 |
not yet
| Closer to reality, less "pleasant"? | Patrik Floding | Solid State | 144 | 27th August 2009 11:17 PM |
| The "Leap-Frog" Method Of Switching Amplifier Control Loop Design | analogspiceman | Class D | 29 | 1st December 2006 03:21 PM |
| Switching amp and "ground rail" | rtarbell | Solid State | 3 | 6th July 2006 03:49 PM |
| WTB: "Audio Reality" book by Rozenbilt | LuckyLyndy | Swap Meet | 0 | 8th November 2004 05:46 AM |
| Page generated in 0.10593 seconds (79.47% PHP - 20.53% MySQL) with 11 queries |
