Hi.
I was searching for a discrete opamp designs and saw an old article by W.Marshall Leach about high bandwidth preamp. In the article he has two designs of a phono preamp and an output stage. The designs are actually discrete opamps, one using BJT's at input and the other FET's. The opamp is designed to work with +-24v. I ran simulations of the opamp and everything seems ok, but for use with +-15v it's a bit weak. Maybe I should add a current source for the LTP, any Ideas? Help is appreciated... Thanks, Udi. Edit: I used bc550/560 instead of the original 2n5210/5087 The schematics: |
#2 |
Well, I replaced the tail resistor with current source....
I'v read that for balanced operation of the input transistors, R1 should equal 2 times R2, and if not distortion will rise Is this true? Thanks, Udi. |
#3 |
no or yes? in mk2 the tail current through the ccs forces 1mA through each leg of the ltp. the 3k6 generates 3v6 and forces 3v across the second LTP tail resistor which in turn creates the bias on the output all ok and r1 is not tied to r2. In mk1, r1 &r2 both dissipate about half supply voltage. r1 carries twice the current of r2 and for a balanced LTP the relationship is important. So for resistor loading the times 2 relationship is yes. regards Andrew T. edit I hope I have the I's & R's the right way round. I cannot see the schematic while typing this reply. |
#4 |
why the different values of second LTP load 1k8 & 1k6? What is the LED voltage? 470r might be a little low for 2mA. regards Andrew T. |
#5 |
You can also read Mr Pass's article about discrete opamps, very good information too
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#6 | |
The different values are like in the original schematic. when I ran simulation, I found that if both values are equal than the transistors are not balanced.... though I don't know why..it seems strange... the led is 3mm and it's voltage - 1.65, so I=(1.65-0.65)/470=2.12ma, so that's ok. Thanks... Udi. |
#7 |
hi udip,
When using jfet like 2 independant 2N5457 ensure that they are matched because in a real life circuit you will encounter problems if their characteristics (IDSS, yfs, VGSoff, etc) are too different (DC offset, linearisation, etc). On way to compensate is the use of a trim pot between the sources of the jfet. fab |
#8 |
Hi fab,
I must say that you are correct, I'v just finished building this opamp with no special matching between the fets (just idss), and it worked, but I had something like 5 - 10v offset!! I guess it's important to match them perfectly... Anyone knows how to cascode the input fets?? Thanks, Udi.
"Things should be as simple as possible, but no simpler" Albert Einstein |
#9 |
Hi again!!
Day by day I'm learning new things about opamp design, input stage, vas, output, current sources, current mirrors, etc. But why do we need a current source (T5) for a current source like in this elektor scheamtics??!?! I'm confused... Thanks, Udi.
#10 | |
https://mrevil.asvachin.eu/ |
| My Leach Amp Clone (LEACH 150) | panson_hk | Solid State | 28 | 15th August 2011 08:12 PM |
| High Current Leach/leach super amp | bowdown | Solid State | 41 | 2nd March 2011 02:15 PM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Leach Superamp vs Leach 4.5 | Samuel Jayaraj | Solid State | 4 | 26th October 2002 09:20 AM |
| Leach amp vs super Leach amp | supernet | Solid State | 0 | 21st February 2002 10:16 PM |
| Page generated in 0.12269 seconds (82.87% PHP - 17.13% MySQL) with 11 queries |
