Old 28th January 2005, 06:26 PM   #1
AndrewT is online now AndrewT  Scotland
Question RC constants & power amps
Hi all,
Q1. Is there a relationship between the Hi pass filters in a power amplifier a) the DC block at the input and b) at the DC block (gain =1) on the NFB lower leg?
Q2. Should the RC time constants be different by a set amount?
Q3. If different which should have the larger time constant?
Q4. Can the RC be the same?
Q5. Are any other roll off points related to these two filters?
hope to hear from you all
regards Andrew T.
Old 28th January 2005, 06:42 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I will try to give it a shot on some of your questions
Q1 to Q4: The input Hi Pass should have a higher freq than the NFB, otherwise you will have a gab not covered by the NFB resulting in unwanted low freq amplification.
However many uses DC NFB that solves the filter problems
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 28th January 2005, 06:49 PM   #3
Hi ACD,
do you mean DC NFB = DC servo? or something else. Please explain.
regards Andrew T.
Old 28th January 2005, 06:53 PM   #4
Jan Dupont's Avatar
By DC NFB I mean no cap in the feedback to Gnd!
In this way, small DC offsets will be corrected by the NFB.
DC-servo is a complete other thing
Old 28th January 2005, 07:01 PM   #5
Thanks ACD, that's clear now. Feedback frequency = 0Hz and input frequency is much higher, fits with your recommendation.
regards Andrew T.
Old 28th January 2005, 07:06 PM   #6
Jan Dupont's Avatar
High pass on input at app. 5 to 10 Hz should be ok, depending on what you want from the amp
Old 29th January 2005, 10:35 AM   #7
djk is offline djk
djk's Avatar
Power supply caps and load form a pole, the NFB cap must have its pole higher than this.
The input pole must be higher than the NFB pole.
NAD uses small supply caps that would normally force the input pole to be quite high, so they make the input pole a two pole filter with a Q=1 (cute).
Old 30th January 2005, 07:36 AM   #8
Hi DJK,
how do you turn the PSU/load into a pole?
Use V/I to generate the load R?
What current(I) do you use for the test condition? max power into nominal load or max current of output stage or idling current?
regards Andrew T.
Old 30th January 2005, 07:53 AM   #9
Graham Maynard's Avatar
Hi djk,
Yes, and these interacting poles can sometimes make bass notes sound completely different as you turn the volume up. I've heard it as a 'pumping' or 'pouf' sound as a bass driver causes phase shift.
I have for some time now simulated my circuits by applying zero signal input and moving the signal generator to the power rails. This can show up surprising results below 1kHz, not least illustrating a need for high series input capacitor value, if not DC coupling.
Cheers ........ Graham.
Old 30th January 2005, 08:04 AM   #10
djk is offline djk
djk's Avatar
I figure minimum load impedance seen by the power supply and the total filter capacitance of either the positive or negative supply.
Example
Hafler DH220 has a pair of 10,000µF and is driving a stereo 4 ohm load.
I use 10,000µF and 2R to calculate the pole of 8hz.
Lengthy Time Constants for PSU's iUSERTLO72p Power Supplies 4 13th November 2007 03:50 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
FS PA02 Power op-amps +/- 18v, 5 amps modifry Swap Meet 0 11th August 2004 07:45 PM
pre+power amps vs integrated amps pkgum Solid State 4 22nd November 2001 01:46 PM
Page generated in 0.09579 seconds (77.10% PHP - 22.90% MySQL) with 10 queries
