Old 27th January 2005, 02:29 PM   #1
hienrich's Avatar
Default 1600watt!!! power amp
hi guys,
its been long but this time i'm here again with this.
I mean with this circuit i found from Matsoft free schemes
I wonder if this thing works, and if so
what might be its recommended components, becuase I think
its supply rails are just very high for the diff amps.
regards,
hienrich
(thanks to DX, AKSA, and every one who helped me with my last thread,
People, you helped me and every one in the thread a lot. )
Old 27th January 2005, 02:51 PM   #2
Dragance007's Avatar
Send a message via ICQ to Dragance007
I think this member can help you about this schematic !
http://www.diyaudio.com/forums/membe...o&userid=33092
Old 27th January 2005, 03:42 PM   #3
The one and only
Nelson Pass's Avatar
It takes an 160 volt peak to deliver 1600 watts into 8.
I don't see that off a circuit with 75 volt rails. Is there
something else going on?
Old 27th January 2005, 04:50 PM   #4
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi !
I am sorry to say this... This circuit is "horrible"...
A symetrical diffamp without any RE's at this supplylevel
is deadly thermal unstable. Also the vas is missing ANY RE.
It's very likely that this does not really work.
Also it has only 300watts into 8ohm. When connected to 8ohms
it's likely to blow. At 4ohms it will blow. You need at least 3 or 4
times the outputdevices on a BIG heatsink.
The diffampbjts with to92 will already be above 40°, the bias in
vas is only defined by temperature of devices.
If this is your first amp to build, try something smaller, like +/- 24v,
just for learning...
Mike
Old 27th January 2005, 06:31 PM   #5
I think this thread is about the same amp design.
Has any one built this 1KW amp?
He states that more output devices need to be added...
I take it the concensus here is that it is still not a good design?
Bean
Old 27th January 2005, 08:21 PM   #6
hienrich's Avatar
Default a bomb scheme....
maybe this is just a formula for a little bomb. So much is
lacking.
That's why I'm also in doubt if this really works.
Or may be there is a typographical error on the supply rails.
I'll try to read the other thread.
regards,
hienrich
Old 28th January 2005, 09:49 AM   #7
djk is offline djk
djk's Avatar
You want something that works?
Got a TIFF viewer? Go to:
http://patft.uspto.gov/netacgi/nph-P...S=PN/5,387,876
and click on 'images'.
That output stage with ±95V will drive 1KW into 2R, two bridged on ±80V or so will drive 1600W into 4R.
Use the Leach front end.
Outputs = MJ21193/94
Drivers = MJL1302/3281
Use two 30-0-30 1KVA (or bigger) in series to get the correct voltages.
Old 28th January 2005, 10:12 AM   #8
MikeB's Avatar
Bean
This is not a bad design, but at supplylevels of +/-95volts i would
recommend something more reliable.
The design posted there is very sensitive to supplyfluctuations,
a few volts more can heat it up, and few volts less result into ClassB.
Old 28th January 2005, 11:09 AM   #9
uli is offline uli  Austria
Guess, its into 2 Ohms.
But that wont work either
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 28th January 2005, 11:25 AM   #10
hienrich's Avatar
hmmmmmm........
Yah,
I think the Leach in the DIFF and the VAS. I guess this is appropriate, but with out the protection circuits.
I'll try to work on this
actually becuase I've got numbers of MJL21194's.
the amp interests me alot....
hienrich
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Page generated in 0.11600 seconds (86.94% PHP - 13.06% MySQL) with 11 queries
