Old 27th January 2005, 04:01 AM   #1
crippledchicken's Avatar
Question ps bypass caps on sub plate amp?
would it be of any benefit to bypass the 2 10k ps caps on a 240 watt rms sub plate amp with some .1 uf stacked films as they don't apear to be of high quality or, due to the limited frequency range would it be a waste of time? thanks, crippledchicken
Old 27th January 2005, 05:14 AM   #2
Stocker is offline Stocker  United States
couldn't much hurt.
Jesus loves you.
Old 27th January 2005, 05:41 AM   #3
Originally posted by Stocker
couldn't much hurt.
hi stocker, that's kind of what i thought so, if i get a chance, i think i'll try it just to see if it makes a difference at all as i've never tried it on a sub amp yet. thanks, crippledchicken
Old 27th January 2005, 09:36 AM   #4
djk is offline djk
djk's Avatar
You're better off to try 22µF
Old 27th January 2005, 12:55 PM   #5
thanks djk, i'll try that! cheers, crippledchicken
Old 27th January 2005, 03:55 PM   #6
jackinnj's Avatar
bypass caps are best used as close as possible to the output devices. this is going to entail taking the amp apart -- and you might find that the manufacturer already bypassed them.
Old 27th January 2005, 07:55 PM   #7
djk is offline djk
djk's Avatar
More than 90% of all equipment lacks proper power supply bypass caps.
Old 27th January 2005, 09:46 PM   #8
True in my case... My own sub plate amp was bypassed with 2x4700uF and that's it.
Jesus loves you.
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 04:24 AM
can you bypass internal crossover on BASH plate amp? thadman Solid State 2 2nd December 2006 08:16 AM
Bypass caps on crossover caps... :D quickshift Multi-Way 19 27th November 2005 12:59 PM
PSU bypass caps Sunsun22 Chip Amps 2 30th August 2004 01:02 PM
Bypass caps Praise! Parts 1 9th April 2004 01:28 AM
Page generated in 0.09288 seconds (74.26% PHP - 25.74% MySQL) with 10 queries
