Old 26th January 2005, 07:41 PM   #1
Default RCA thread - need a tap. What size?
Please help. I have just finished the P101 from ESP. I am
delighted with the results. The heat spreader is 1/4" thick
AL. I would like to tap threads for the RCA jacks, but cannot
identify the tap I need. Can anyone tell me the tap size?
Thanks ....
Steve
Steve Beccue
Old 26th January 2005, 09:10 PM   #2
BrianDonegan's Avatar
I think we'll need a little more info. Maybe a picture and/or brand of the RCA?
-b
Old 26th January 2005, 09:49 PM   #3
BobEllis's Avatar
are you sure that you want to ground your input jacks to the chassis? It certainly has been done, but ground loops are easier to eliminate if the RCA is isolated from the chassis.
Old 26th January 2005, 11:04 PM   #4
The RCA jacks I have are Dayton Audio, solder type, part number 090-278. They are gold. I presume all threaded RCA jacks with this type of nut are the same thread..... (And maybe I'm wrong)...
Thanks for the comment about avoiding ground loops. I think
I have this under control.
Steve Beccue
Old 26th January 2005, 11:58 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Steve,
No, they are not all the same size. Take the jack to a hardware store and try different nuts on. Be aware it may be metric or imperial.
-Chris
Old 27th January 2005, 12:41 AM   #6
The hardware store will likely have a gauge board with different threaded holes you can try it in. Are you looking for the thread size of the plastic part or the tiny brass part on the end. The plastic part should be a standard imperial thread size, as the metal nuts typically used on these are (wait, I'm thinking of the Dayton binding posts - sorry).
-b
Heat Sink tap/thread size wicked1 Pass Labs 5 24th August 2009 02:52 PM
What thread size are Allen & Bradley pots? MikeHunt79 Parts 3 4th June 2009 06:34 PM
thread size for aluminum ultrachrome Parts 12 19th March 2005 01:21 AM
Speaker size v Room size cliffy Multi-Way 6 19th February 2005 08:34 AM
Craftsman soldering iron tip thread size? Darren Nemeth Parts 0 10th February 2005 06:50 AM
Page generated in 0.14912 seconds (87.48% PHP - 12.52% MySQL) with 10 queries
