Take a look at this new TI chip for use as unbalanced to balanced driver: http://www.ti.com/corp/docs/landing/...+EM+ths4509-em
If it sounds good... it is good! |
#2 |
A little off topic, but:
on theyr curves, what are HD2 and HD3? I assume they're not signal harmonics since they are at a lower frequency, and that HD3 is closer to the signal than HD2 is
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#3 | |
#4 | |
HD2 is 2nd harmonic distortion, HD3 is 3rd harmonic distortion. In a differential amp you would expect HD2 to be lower than HD3, which is in the curves (up to a certain high frequency where it breaks down). Jan Didden
/Another new issue: Linear Audio Volume 3! |
#5 |
agreed, but harmonics at a lower frequency thant the fundamental?
#6 |
the power supply is limited to +- 2.5V ... this is a bit too low for line level audio apps. the package is a bit hard to work with for non-machines. less than 0.5mm contact spacing.. the contacts are just 0.2mm high (see scba017d ) regards T |
#7 |
Very low supply voltage, and a tiny package. I can't think of an immediate use I would have for them.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 | |
#9 |
It is shot to the dark - this circuit isn't for audio using. This discussion ist losing time
#10 |
The one and only
Looks like a variation on the THS4130, whose circuit is
nicely described in my patent #5,376,899. |
| converting BAL to UNBAL using tubes and without transformers | sunrise | Tubes / Valves | 101 | 24th November 2008 07:26 PM |
| PCM1804 bal/unbal adc | meta | Digital Source | 14 | 7th February 2007 06:44 AM |
| Bal-Unbal-Bal Cable Wiring | richie00boy | Everything Else | 3 | 3rd February 2005 11:08 AM |
| Bi-amp with Aleph P bal. and unbal. outputs | Sony | Pass Labs | 3 | 21st December 2004 07:09 PM |
| unbal. linedrive/lineamp | Per | Solid State | 2 | 25th October 2002 11:25 AM |
| Page generated in 0.10527 seconds (78.06% PHP - 21.94% MySQL) with 10 queries |
