I recently changed 3 Opamps in my Parasound P/HP-850.
(AD 712 to BB OPA2134) Now the left channel has lower High frequency response. Any ideas why it is so? I also tried going back to the original AD 712 but the problem does not go away. |
#2 |
Hi mura,
Check the solder joints around where you were working. You either have a solder bridge, or short, or you have desoldered a component. Also give the unit a shake in case you have some stray solder bits. -Chris |
#3 |
I have compleatly checked all solder joints , loose components ect,
Any idea what component can cause reduced HF response? |
#4 |
Hi mura,
I am not familiar with this unit. Does it have tone controls? Possibly a broken tone control pot? Normally you would have to replace a capacitor with the wrong value. Can you have another tech look at it? Another set of eyes can fix any things. -Chris |
| Parasound 2500 AV Controller preamp | doerfast | Swap Meet | 0 | 23rd March 2009 05:48 AM |
| Parasound P/HP-850 Preamp Schematic Request | dtm1962 | Solid State | 0 | 20th March 2008 04:58 PM |
| Parasound P/HP - 850 Preamp modifications | firekat | Solid State | 0 | 10th December 2006 03:36 PM |
| FS: Parasound PL/D1100 Preamp John Curl Designed | Zero Cool | Swap Meet | 2 | 2nd November 2006 02:59 AM |
| parasound p/ld 1100 preamp | crippledchicken | Solid State | 0 | 16th January 2004 11:32 PM |
| Page generated in 0.06873 seconds (76.11% PHP - 23.89% MySQL) with 10 queries |
