Old 23rd January 2005, 08:03 AM   #1
Send a message via MSN to Scribble
Default P88 preamp power supply
Ok so im having a go at rod's preamp project 88: http://sound.westhost.com/project88.htm
I want to build the unit as a self contained unit including the power supply. My question is can anyone recommend a nice stable, mains powered, PSU for this project which i can include in the box with out the needs for a wall transformer?
Wound i be able to use this PSU design http://sound.westhost.com/project05.htm And just include a 16v transformer wired straight up in the case with the mains connector on the back?
Any help is appreciated.
Thanks for your time,
Scribble
Old 23rd January 2005, 08:21 AM   #2
maxw is offline maxw  United Kingdom
maxw's Avatar
I didn't read through all that article but if you just need a +/- 15 V PSU then here is the one I made:
Help with regulated +/- 15V PSU schematic
All the parts are from Jaycar
Old 23rd January 2005, 08:50 AM   #3
udip's Avatar
You can use the P05 preamplifier supply with no problems at
all, and you can put a 16 - 20v transformer inside the box,
just make sure it's placed far enough from the preamp.
If this is not possible, that u can put a buffer between the tx
and the preamp (piece of metal, etc.).
Udi.
6sn7 Preamp power supply ambience exists Tubes / Valves 27 26th August 2008 12:12 AM
preamp supply w/ 48v power impsick Power Supplies 16 27th April 2007 11:36 PM
Preamp Power Supply Suggestions TomSSS Car Audio 18 26th September 2006 04:30 AM
Need Help for Power Supply for gg Preamp vangogh-hk Tubes / Valves 7 8th December 2005 02:00 PM
Boz Preamp Power Supply beppe Pass Labs 0 5th March 2002 08:11 PM
Page generated in 0.06900 seconds (72.61% PHP - 27.39% MySQL) with 10 queries
