CRCRC vs. LCLCLC which is better and why? - diyAudio
Old 22nd January 2005, 04:03 AM   #1
Clarkcr is offline Clarkcr  United States
Clarkcr's Avatar
Default CRCRC vs. LCLCLC which is better and why?
I putting together a PSU for an amplifier and am wondering if I should use large resistors to drop voltage on the rails or use toroid inductors. Can anyone tell me why I wouldn't want to use inductors?
C
Old 22nd January 2005, 10:07 AM   #2
jesper is offline jesper  Sweden
Because a LC circuit is a resonant, low loss system with possible very ugly transient responce.
However, as allways, if designed proporly, it could be a good comprimise between filter attenuation and accapteble transient responce.
/Jesper
Old 22nd January 2005, 10:22 AM   #3
Find out for yourself with PSUD 2 (search for Duncan PSUD2) and be wiser.
Sounds like you want to drop the voltage. Depending on your component values - an inductor drops the voltage AND increase utilization of the transformer (a good thing) in an LC configuration.
Petter
Old 22nd January 2005, 01:37 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A LC cell provides 12dB/oct filtering but the L and C values have to ve carefully selected to create a damped non-resonant system, depending on inductor Rdc and capacitor ESR
The LC filter design goes more and more complex as more LC cells are added in series, it will definitely require custom-wound inductors with custom inductance and Rdc values and some minimum load resistance on the output to avoid resonance
In the other hand, a RC cell provides only 6dB/oct filtering but it will never resonate, even in case of crazy R and C values, and you can easily place several in series
Old 22nd January 2005, 02:58 PM   #5
Clarkcr's Avatar
Thanks Eva....that's a great help!!! What is meant by ESR and Rdc values?
Would these inductors be impossible to get right in a Class A amplifier? Or would it be preferrable sense the dissipation is at a constant. I'm lacking some knowledge here, so bare with me.
Chris
Old 22nd January 2005, 04:23 PM   #6
Hi.
what kind of classA topology are you referring to.
I can recall only one that has constant current in the supply lines. All the common topologies have varying current in the supply lines and from this forum and many others I would estimate that 99% of classA amps are not constant current.
The supply rail currents are generally modulated in phase with the input/output signal.
Back to your question I would recommend further research but avoid LCRC. Some manufacturers have used this and it does suit classA or very high bias classAB. However the minimum and maximum spread in acceptable current to stay in the inductor controlled region is fairly narrow and you may as an amateur find the cost of trial & error design too expensive.
CLC should work fairly easily without having to discard too many components.
Have you considered a capacitance multiplier? JLH proposed a basic version and ESP has developed it a little further. I did read on another thread that this did not suit the sound of another classA design.
finally PSUD2 is worth using.
regards Andrew T.
Trying to understand Power Supplies - The first Cap in a CRCRC Brit01 Tubes / Valves 17 13th August 2009 01:13 AM
super regulator vs a good stiff LCLCLC power supply audionut Parts 4 30th April 2007 08:01 PM
CRCRC vs. LCLCLC which is better and why? Clarkcr Pass Labs 67 27th January 2005 05:19 PM
Copyright 1999-2017 diyAudio
