Just for fun today I put together very simple amplifier based on the lm 3876 circuit. I used Avel 25-0-25 transformer, 25a bridge, and two 10,000 uF Mallory for the power supply. I didn't really know what to expect when it was complete. I am using onkyo 2ch receiver connected to my computer and diy 2way speakers. I went ahead and replaced one channel with the lm3876 ic amplifier and fired it up. I was surprised that it sounded better than my receiver. The biggest difference in sound is the bass response, compared to the receiver it made my right speaker sound much better. There is no hum or noise when there is no signal, don't hear anything with my ear close the speaker. I used my maudio 24/96 as the source w/o a passive volume control in line.
I am going to finish it up and use it as a computer speaker amplifier ![]() I am really impressed with this little IC. thanks for reading. |
#2 |
frugal-phile(tm)
What circuit did you use? Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
#4 |
#5 |
frugal-phile(tm)
Nice dead bug you have there... one of the things that pushes the peformance of these up is how physically short you can get the feedback resistor. Some guys will actually shave back some of the plastic and mount an SMD resistor to get a very short path -- yours is longish.
dave
#6 |
I do not have any experience with these except for servicing consumer gear using them.
In the typical Jap home amp they work quite decently imo. In my experience on other amps I have found that the quality of the feedback AC shunt (R5 in above diagram) is important. Decoupling caps are important too ime. Ime, SMPS grade caps work a lttle better and can give a more pleasant sound. Dave, any experience with this on these type amps ? Eric. Ps - I have recovered an SMD chip in the past by grinding the epoxy back with a dremel tip and exposing the broken leg so that I could attach a wire. Not difficult at all. |
#7 |
Hi Eric,
What is a dremel tip? Vivek |
#8 |
#9 |
OK. Thanks.
Vivek |
#10 | |
frugal-phile(tm)
dave
| Parallelling two LM 3876 for sub | Vidi | Chip Amps | 32 | 10th November 2010 08:09 PM |
| The new Altec 604-8H III, 212-8A Impressions? | DaveCan | Full Range | 32 | 17th December 2008 07:08 PM |
| Why is 3876 rarely used by folks in this forum? | goering | Chip Amps | 6 | 2nd September 2004 06:59 AM |
| Gainclone: Impressions... | roibm | Chip Amps | 0 | 2nd April 2004 10:18 AM |
| First Impressions | Jhovis | Multi-Way | 4 | 19th January 2004 03:45 AM |
| Page generated in 0.10370 seconds (82.19% PHP - 17.81% MySQL) with 11 queries |
