Old 20th January 2005, 07:05 PM   #1
Bensen is offline Bensen  Belgium
Bensen's Avatar
Default High quality amp with 2sk1530 and 2sj21
High there,
Does anyone know a good amp (circuit) using the 2sk1530 and 2sj201 devices. Because these are the only devices I can buy which are already matched.
I build the original Crecendo amp (1982) with the 2sk135 and 2sj50 (TO3) devices. I used devices that aren't matched, but it still runt very good after 7years.
I want a bit more quality and power (140W/8ohm).
I have also made the Crescendo ME with the newer devices, I use that amp as plate amp in a sub.
Another option is working with one P and N device, but than I probably can't run 4ohm loads with high power.
Thanks in advance
Ben
Old 20th January 2005, 08:24 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You can build any amp you like, as I don't think there is a special design to fit only the 2SK1530/2SJ201
Have a look in the forum on all the interesting projects and amps, and pick one
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
High Quality Sub Drivers matt09 Subwoofers 18 15th March 2007 09:22 PM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
Very high quality crossover Bull Multi-Way 15 25th April 2004 12:33 PM
High Power High Quality Digital Amp aspycaudio Digital Source 0 6th December 2003 09:49 AM
Page generated in 0.07184 seconds (65.88% PHP - 34.12% MySQL) with 10 queries
