diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Technics SU-X101 amp schematic wanted, and other questions (http://www.diyaudio.com/forums/solid-state/49937-technics-su-x101-amp-schematic-wanted-other-questions.html)
falcott 20th January 2005 06:54 AM
I have rescued from the rubbish a Technics SU-X101 "New Class A" amp (circa 1990) that is dead. Well, not exactly dead, for at full volume, amongst the hiss there is a ...faint... sound of music. There is nothing visually wrong inside. I am getting full power to the chip, no problems there. Any clues as to what might be wrong? :confused:
Any way of ascertaining if the chip is dead or alive without a 'scope? If it is dead, does anyone know where to obtain a replacement cheaply?
Does anyone have a schematic for this amp? The chip is labelled SV1-3102 (14 pins). What is the pinout for this chip?
Over all, the layout of the amp is rather sp****, and fairly basic in construction though well enough built, and looks ripe for hot rodding. Any hints for improving it? (apart from throwing it back into the rubbish pile? :rolleyes: )
Thanks for any help! :)
EDIT: the bleeped word is defined by my Oxford Dictionary as "thinly scattered." Why I have been chosen to be censored for using the word s_p_a_r_s_e I have no idea, other than I might usually sit on a thinly scattered part of my body when I remove two items first... If you can follow me :eek:
falcott 20th January 2005 05:48 PM
Anyone?
Tarzan 21st January 2005 06:43 AM
Hi, have alook at this address:
http://www.gmkelektronik.de
they ave a lot of schems.
Allthough not the SU-X101 (they have the ..102) but you can ask.
They sell very cheap, 1 Euro!
falcott 22nd January 2005 06:27 AM
Thanks for the lead. I emailed, but unfortunately they do not have the schematic I need... :bawling:
Tarzan 22nd January 2005 08:12 AM
do have a look here:
http://schforfree.seedhost.com/archi..._Amplifier.zip
its the 102 but just try it out.
Try this forum: http://forum.eserviceinfo.com/
Cheers,Marco
Copyright 1999-2017 diyAudio
