Old 20th January 2005, 07:26 AM   #1
DarkHorse's Avatar
Lightbulb 3W Pure Class-A AMP
I design this Circuit Lastyear(2004)...
But Mr.Pass(Nelson Pass)had work it out as preamp in 1996...
God..
Ok,let's see the Circuit:
Old 20th January 2005, 08:33 AM   #2
DarkHorse's Avatar
per channel power waste about 52Watte,
Output 3.25W(6ohm load)!!!
Old 20th January 2005, 09:04 AM   #3
What do you waiting from this connection ?
Old 20th January 2005, 11:04 AM   #4
DarkHorse's Avatar
yes,I'm a new comer of diyaudio...
what do you think of this circuit?
I want to build one of this amp...
but short of some compenents...WoWo
Old 20th January 2005, 11:09 AM   #5
If you are newcomer, all is OK - I wish you best results and many enjoy with it .
Old 20th January 2005, 11:35 AM   #6
DarkHorse's Avatar
Thank you,Mr.Upupa Epops
about 1 or 2 month later,I will show This AMP to you all..
it's so simple and easy to do,but need very large heatsink..
and high power transformer..
Old 21st January 2005, 10:58 AM   #7
PMA is offline PMA  Europe
PMA's Avatar
Nice design . Please let us know your listening impressions. Maybe you are losing a little bit more power than necessary
Old 21st January 2005, 12:16 PM   #8
Circlotron's Avatar
Darkhorse, this is one I made about 2- 1/2 years ago and is still going well. It uses a big choke instead of a resistor and so it has half the power loss than usual.
Circuit. http://www.diyaudio.com/forums/attac...amp=1054194645
The complete thread.
My first ever Class A amp.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 22nd January 2005, 01:16 AM   #9
DarkHorse's Avatar
hi,PMA:
the amp didn't work out yet!But trying my best now--buying electric device and its out shell ..etc
I hope the circuit will sounds good,my friend told me that can it compare with 2A3 vacuum tube amp..
in fact,I don't own both of them now..haha
same as you expect,I doing things for it!
have fun!
hello,Circlotron:
I read your post thread "My first ever Class A amp",we almost have same idea of class-a amp form,yours is using inductance winding,the efficiency near to 50%...High!I saw the same idea in passlab.com, nelson pass new design zen-7,good idea..
but the high quality inductance is hard to DIY or buying!is it?
I don't want to change my mind-Use aluminium case power resistance,only this I can choose for this circuit..
and I hope it will sounds truly..
happy!
Old 22nd January 2005, 01:24 AM   #10
DarkHorse's Avatar
I have make some change with the circuit..
now it don't need regulated power supply..
more high voltage supply,burning 67watte to get 4watte(RMS) output power!just like SOZ's hot..
see the update schematic diagram:
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 07:08 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 10:54 AM
Pure Class A topology Bigred Solid State 4 16th September 2007 12:31 PM
Pure Class A amplifier with FET - schematic wanted DJG Solid State 37 6th September 2002 02:02 PM
Page generated in 0.11814 seconds (71.28% PHP - 28.72% MySQL) with 11 queries
