3W Pure Class-A AMP
3W Pure Class-A AMP
Old 24th January 2005, 07:29 AM   #21
Upupa Epops is offline Upupa Epops  Czech Republic
This distortion is too high, later you will be not satisfied with him , belive to " old tomcat " .
Old 24th January 2005, 08:21 AM   #22
DarkHorse is offline DarkHorse  China
DarkHorse's Avatar
ahaha..OK,I trust you that the 14W class-A amp's distortion is too high(full output state)!I will consider let this project push rear!
at present,I will do 4W class-A amp first..
as a young man,I need more experience in DIY practice!
have fun!
WINCO
Old 24th January 2005, 09:52 AM   #23
4 W are for ...., it is only to the bedroom, not for serious listening .
Old 25th January 2005, 03:14 AM   #24
DarkHorse's Avatar
yes,4W(RMS) seems too low today,I want to build this low power
amp just for proof my idea.
and I have several 3inch full frequency loudspeaker(SONY joint-stock unit,4ohm,20W),sensitive seems OK,series-wound two is 8ohm,haha..it is so cheap($2 each):
Old 25th January 2005, 06:27 AM   #25
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Those speaker are wonderfull, if you used it well tuned
I have here, a Sony speaker, made of plastic, and they are using those speakers...my God!
The small ones beat, not in volume, but in quality, all i have related home systems here...those you buy in shops, not hi end amplifiers and hi end speakers...i am talking those Systems...with CD, FM Radio, and sometimes with cassette decks...those are disappearing, those cassete decks.
Also, it can reproduce 30 hertz, and sounds very nice...will depend the speaker tune.
My speaker size are
25 centimeters large
25 centimeters deep
30 centimeters high
Has two tubes inside, tuned ducts, 2 inches diameter and 20 centimeters long...one from front panel to back panel, and the other from back panel to front panel.
The small Sony System that use it is some 10 RMS each channel boom box, have reinforced bass.
But i tested those speaker with other amplifiers, and always sounding very nice....and with big bass...believe it or not!
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 25th January 2005, 07:08 AM   #26
DarkHorse's Avatar
hi,carlos:
your sound box is so magic!is it using 3" SONY unit?
and how much 3" unit per box?
I have a crazy idea:build a sound box using 8 PCS unit which I have Posted earlier!and it's sound quality will be more stronger than using only one unit.and can load more power,oh..I dreaming ..
regards,
WINCO
Old 3rd March 2005, 09:34 AM   #27
DarkHorse's Avatar
hi,dear DIYer:
I will work on with this updated schematics:
Old 3rd March 2005, 09:48 AM   #28
God bless the Earth, if all Chinese start make amps with this efficiency . But seriously : look around, exist many better connections , think on Gaia.
Old 3rd March 2005, 10:03 AM   #29
DarkHorse's Avatar
hello,Upupa Epops:
a long didn't take with you,are you join to green peace^@^,
many chinese not like me---with a little crazy dream...
but,I think it is so fit to me,except it's low efficiency...hohoho
it expense 64W each channel,stereo just about 130W,lower than ZEN2(72W~80W/per channel),of cause it's output power not much as ZEN2(10W)...
happy everybody!
WINCO
Old 3rd March 2005, 10:07 AM   #30
Default Hey Epupa, since class D event, your amplifiers turn the daddy of your grandfather in
Age....so.... as we are working in hi top level quality systems...to use in our bedroom... near our ears.... a very serious place, the bedroom, as Human kind was produced there Epupa.
And we do not need power..... we want to hear alone...without disturb neighboors.... 3 watts is wonderfull, as we (mankind) are already researching direct inputs to brain....hehe....some picovolts.....your power will be used to flash lamps only, as a heater or someone heavy to keep the door open in a terrible windy day...to avoid door slamp you will use those big machines near future only to keep doors openned.
Also, Japanese and all Asiat tigers (the Masters of the Universe) ,created the drifting... to put automobile to skid over some special track...to burn tires....and those cars need to be ballanced in weigth..... the big amplifiers will have utility there also....to create some weigth ballance.... to avoid some rear tire loose contact with pavement.
We are in a new world man!.... class D arrived.
Man is going to Mars.
Uncle Sam already show real face
Chinese will be the biggest power in earth
And we will go to dance Samba watching US wars on TV
ahahahaha....today i am very bad....yeah!...real bad!
regards,
Carlos
3W Pure Class-A AMPHide this!Advertise here!
SE Class A 200W PURE Heat lineup Solid State 28 25th November 2008 07:08 PM
Pure Class A Single End Amplifier Idea! Dxvideo Solid State 91 1st September 2008 10:54 AM
Pure Class A topology Bigred Solid State 4 16th September 2007 12:31 PM
Pure Class A amplifier with FET - schematic wanted DJG Solid State 37 6th September 2002 02:02 PM
