i'm looking for opinions on whether there's anything to be gained changing RS 803 8 amp 200v. inline bridge rect. to stealth 15 amp 600v. diodes in a 200 watt sub plate amp being low frequency only? thanks, crippledchicken
#2 |
Let's do some math, shall we?
Wait, we can't... what is the rail voltage inside the amp? What is the highest max and RMS power rating of the amp? Perhaps a better question is, do the combination of full-voltage rails, max current and minimum load ever exceed 8A from the transformer? For how long? If you never get to 8A, you will probably only end up with a cooler set of diodes. If you occasionally get past 8A and the power supply capacitors can't keep up, you may have diodes that last a little longer (60 vs. 50? ) If you have the parts on hand, change them and see how it *sounds* It is likely not going to make all that much difference.
Jesus loves you. |
#3 | |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| Rectifier diodes upgrade | beauty_divine | Digital Line Level | 4 | 28th February 2009 04:07 PM |
| Upgrade For A 78R05 Rectifier? | dantwomey | Power Supplies | 7 | 29th December 2006 07:48 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.09318 seconds (68.66% PHP - 31.34% MySQL) with 10 queries |
