Old 19th January 2005, 02:26 PM   #1
Default Anyone use output stage like this
Hi Everyone...
Has anyone ever seen an output stage like this being used for audio? I believe output stages like this are sometimes used for motor control circuits. I'm trying to design an amp using it and am having problems balancing the two outputs....
http://www.deleveld.dds.nl/outstage.jpg
Thanks,
Doug Eleveld
Old 19th January 2005, 04:06 PM   #2
This circuit is designed to turn the motor fully on in one of two polarities. This is not what you want to do for audio, and it is not surprising that you are having troubles.
Many amps have been made with a balanced bridge output. You are probably better off using common collector output devices instead of common emitter. One example of a balanced bridge output amplifier can be found at:
http://www.diyaudio.com/forums/attac...amp=1077770119
Good luck!
Old 20th January 2005, 11:52 AM   #3
djk is online now djk
djk's Avatar
For audio?
Does a siren driver count?
Your circuit is the same as the Zetex siren driver, rail to rail square wave.
Go to:
http://home.kimo.com.tw/skychutw/
Then click on:
Circuits, and then:
Liquid-Coopled Power Amplifier (Wireless Word, Dec. 1974, p505~507)
Old 20th January 2005, 01:08 PM   #4
Huh? The same?
The output stage i showed is VERY different then the one you showed. Yours uses output devices in a complementary-darlington with the drivers with 4 drivers and 4 output devices. My drivers are normal darlington with the bottom drivers but complementary to the top drivers and shares 2 drivers for 4 output devices.
Doug
Old 20th January 2005, 02:25 PM   #5
DRC is offline DRC  United Kingdom
DRC's Avatar
Doug,
Is your problem differential offset ? I would guess component tolerance / Vbe temperature dependency combined with voltage gain (x16 ?) are the cause. The obvious solution would be some feedback, a servo or both (unless you are trying to avoid that) …
Also, I think your bias conditions are dependant on the common mode input voltage.
dave
Old 20th January 2005, 07:36 PM   #6
djk's Avatar
SInce you have trouble with English I will try again.
Your circuit is the same as a ZETEX siren driver circuit, they make square waves and are generally driven from batteries and need rail to rail operation.
http://lib1.store.vip.sc5.yahoo.com/...ics/kit116.pdf
The circuit I linked to is an amplifier with a DC off-set control and the X feedback scheme favored by Nelson Pass. It may be built with EF or CFP output pairs.
The Hadley 622 at the Skychu site is also another nice bridge amp with the X feedback and has current limiting, DC offset adjust and bias shown.
The original Sumo Andromeda is a BJT version of Charles' FET bridge, but only the FET version is at the Sky site.
The Ampzilla III is a forerunner of the Sumo, it is at the Sky site too.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Page generated in 0.09232 seconds (77.25% PHP - 22.75% MySQL) with 10 queries
