Old 18th January 2005, 12:25 AM   #1
troystg is offline troystg  United States
troystg's Avatar
Default Reverse engineering a servo controller?
Hi All-
I have an "Erath Electronic Suspension Loudspeaker Controller" which I have decided to install in an enclosure with the woofer amp.
The controller consists of a 2-way 24db electronic cross-over @ 125Hz and then the "servo or feedback" circuitry.
In the process of pulling the PCB out of the original enclosure I figured I would try to reengineer the PCB to miniaturize it as much as possible.
The circuit is still covered under US patent so outside of making a "personal use" copy cloning it is not an option.
I will attach several pictures if anyone has free time to assist me with the deconstruction and rebuilding.. We have the technology, we can rebuild it stronger, faster and better...
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 18th January 2005, 12:28 AM   #2
troystg's Avatar
2
Troy
Old 18th January 2005, 12:28 AM   #3
SY's Avatar
Holy mazolie! The name LWE really gets the nostalgia flowing. They did one of the first "super" speakers back in the '60s. Haven't heard that name in 35 years, at least.
How old is that unit?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 18th January 2005, 12:29 AM   #4
troystg's Avatar
3
Troy
Old 18th January 2005, 12:33 AM   #5
troystg's Avatar
The unit is around 4 yrs old..
Mr. Erath is still alive and kicking in Abbeville and Mr. Gerald is still selling his stuff.
Mr. Erath has come out with a few new products but they are still based on "his" production capabilities and that is why I am looking into redoing/shrinking the circuits... Look at the traces on the PCB... That is a 4-5 yr old board!!
Troy
Old 18th January 2005, 12:34 AM   #6
troystg's Avatar
4
Troy
Old 18th January 2005, 12:36 AM   #7
troystg's Avatar
5
Troy
Old 18th January 2005, 12:37 AM   #8
troystg's Avatar
6
Troy
Old 18th January 2005, 12:38 AM   #9
troystg's Avatar
And lucky # 7
The device compares the input of the woofer amp to the output of the woofer amp and makes adjustments accordingly. It also compensates for the woofer being in an enclosure that resonates at 70(!) Hz.
That's right, I have a stereo pair of 15" woofers each in a 1.25 cu ft box that are flat from 20 Hz up to and cross over at 125hz.
Troy
Old 18th January 2005, 03:27 AM   #10
thomas997's Avatar
Those small silver caps look nice...
Reverse engineering Krell KMA 160 jwb Solid State 193 29th April 2012 10:09 PM
Reverse engineering a JVC stereo amp jovial_cynic Chip Amps 6 18th April 2008 04:51 PM
reverse engineering a box Zero Cool Multi-Way 1 16th July 2007 10:00 PM
reverse engineering a crossover? BlackDog Multi-Way 30 9th December 2005 03:01 PM
Page generated in 0.09922 seconds (74.11% PHP - 25.89% MySQL) with 11 queries
