Old 17th January 2005, 08:23 PM   #1
Default need input on SS buffer w/transformer line amp.
ok, i was reading some stuff about using a transformer as the volume control, or even a regular nickel transformer connected to a 10K volume control...
problem is with input impedance of this circuit is very low for a source component and output impedance very high for the inputs of power amps etc..
so why not put a BJT or MOSFET buffer circuit at either front end or after step-up tranny or both??
common emitter or source follower setup?
maybe even power these of 12v SLA batteries.
problem is the transformer I want to use is made out of nickel and I don't want to use coupling caps if I can help it.
so ideas?
The nickel transformer i have seen is a 150:10K.
Should I just buffer the input so that I can drop my volume control to say a 1K?
Then how do I connect a nickel transformer that doesn't like DC to a mosfet or BJT?
Thanks!!
It is not you... you are it.
Lundhal line input transformer question... sklimek Parts 9 11th January 2011 07:43 PM
Jensen JT-11P-1 Line Input Transformer csrote Analog Line Level 0 13th December 2008 09:40 PM
PCB mount line input transformer question audiowize Tubes / Valves 0 11th July 2008 07:05 PM
Line output as line input transformer? bambadoo Tubes / Valves 7 22nd January 2008 06:44 AM
Line input transformer for unbalanced to balanced conversion okapi Chip Amps 23 12th January 2008 05:29 PM
Page generated in 0.07324 seconds (71.65% PHP - 28.35% MySQL) with 10 queries
