Hello,
Does anyone have a schematic for this rotel pre? Thanks Kevin |
#2 |
Hi Kevin,
Please take no offense... but the Rotel 970 pre is a real POS. Its really not very upgradeable nor worth fixing. I replaced mine with the BOSOZ in the PASS fourm. Seriously 600% better. I'm not stretching the truth here. My BOSOZ is mated to a Rotel 990 amp. The amp is pretty darn good though. I'm happy to share more if you email me. Good luck, -David |
#3 |
How did you measure the 600%?
The Rotel is no worse than any other IC based pre. |
#4 |
DIY !
The gaincircuit would be like fig 10 here: http://hjem.get2net.dk/bencar/opamp/opamp1.htm
I changed op-amp to AD825x2, and gain-resistors from 10k-1k to 8,2k-2,2k, and replaced DC-blocking caps with good 10uF bi-polars. Also added a blue motorized Alps pot and remote-kit from a diy-member from Denmark... No way near a X-BoSoZ & attenuator, but ok... Arne K
Ars longa, vita brevis |
#5 |
Hi Kevin,
A person can build a PASS BOSOZ for a very reasonable cost. I bought a surplus metal case for $10, the boards from Kristian K, trafo from Avel-Lindberg, and the rest of the parts from Digikey as a low cost experiment. I have NEVER plugged the Rotel in again. I sold the Rotel 980 pre and that covered the costs to build the BOSOZ in a nice case. Seriously, the sound difference is so dramatic you'll kick youself for not doing it sooner or in trying to upgrade the Rotel. Good luck, -David http://www.passdiy.com/pdf/balzenpre.pdf |
#6 |
diyAudio Moderator Emeritus
I assume you did not mean RC980BX as mentioned in your post. RC980BX cannot be compared to the much cheaper built RC970 etc.
Coincidentally I have a 980 at home and it is one of the better preamps I heard till now. Not one I would discard to build a DIY preamp anyway.
It's only audio |
| Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player | Staykov | Digital Source | 5 | 16th May 2012 12:24 AM |
| Problem with Rotel RB-985 MKII 5 channel home cinema amplifier... | hoppaz | Solid State | 2 | 9th April 2009 08:04 AM |
| Krel DSP CDM-1 MkII Pickup Need Schematic | gto127 | Digital Source | 22 | 10th January 2008 01:18 AM |
| Looking for Rotel RC970BX MII schematic | KevinLee | Solid State | 1 | 16th January 2005 07:47 PM |
| Need schematic - Audio Research LS2B MKII | ruangrit | Tubes / Valves | 0 | 5th January 2005 12:32 PM |
| Page generated in 0.14221 seconds (64.69% PHP - 35.31% MySQL) with 10 queries |
