OK, I searched the forum on this one, but didn't found anything, so here goes...
Someone threw an AR amplifier in my lap as part of a deal with a pair of AR-speakers I bought. The amp has a problem in the R channel when output goes over 20%, esp. at lower frequencies and low impedances (4 ohms). ![]() Input is sine on top, output from speker terminal. Questions: A: Where can I find a service manual / schematics? B: Anyone seen this before, clues? C: Is this amp even worth salvaging? I have some experience in tube-amps, but less in solid state. Ironically It's rather simple to find documentation on old tube-amps and new solid-states. But in between those... |
#2 |
I think this was a good quality amplifier for the time; possibly
a quasi-complementary output stage, may have been direct-coupled. The Classic Speakers Page (http://www.****nal.net/speakers/) had schematics, but appears to be completely offline at the moment. I'd check power supply first, especially low-voltage supplies and any regulated supplies. It's been my experience that electrolytic caps in those supplies are unreliable, going open- circuit or high impedance. If the output stage is capacitor-coupled, check those capacitors as well. After that, check the driver and output transistors. |
#4 | |
#5 |
sometimes this helps:
http://web.archive.org more precisely: http://web.archive.org/web/*/http://....net/speakers/ |
#6 |
a r s e n a l over here is a football team. So that makes the censor look a bit silly.
#7 |
Not to mention what happens to: ****nococcus frondosus.
Beam me up. |
#8 |
ROTFL!... Seriously: I have already 'scanned' that site. The AR amps there are too modern. I have found one copy of a manual at:
W7FG It was in poor condition and no schematics. I have not yet received it so I can't tell. Yes, there is a large multicap. Same thing as the old Dynacos; may have to be replaced. Since it seems to be so har finding data on this one, maybe that is telling the tale? It is rare and should be salvaged? |
#9 |
UPDATE: I have received the manual. It had, as I was told, no scematics. Unfortunately. But it makes a reference to it: Dwg. #2935-10.
With that, all measurements, and procedures are described. This means I am really interested in this drawing right now. Anyone? |
#10 |
If I remeber correctly the old AR amp is kind of a POS with an interstage coupling transformer to drive all NPN outputs.
I would gut it and use the chassis for a new project. |
| Solid state guitar amp. help needed! | pilt | Solid State | 8 | 17th April 2011 06:25 AM |
| The Solid State Wiki - Your solid state reference guide | Jason | Solid State | 0 | 25th June 2002 05:26 PM |
| Page generated in 0.10854 seconds (83.72% PHP - 16.28% MySQL) with 10 queries |
