diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Tone controls (http://www.diyaudio.com/forums/solid-state/49573-tone-controls.html)
mik 14th January 2005 12:44 PM
Tone controls
I going to build this preamp with this tone controls ,so where to put tone controls.
Before or after the gain module?
And second question is , if I use NE5532 for stereo preamp should I replace C4 an C6 with 100uF capacitors?
Any help is welcome!
SY 14th January 2005 12:56 PM
Put the tone controls first- and make sure they're in the same box. The tone control circuit has a high and variable output impedance so is probably less suitable for driving cables.
There's no reason not to make the bypass caps 100u regardless of which opamp you use.
mik 14th January 2005 03:46 PM
THANKS SY!
Much appreciated !
Copyright 1999-2017 diyAudio
