Can someone give a brife explanation and maybe some example (shema) of npn open collector output stage in audio amp?
marijan |
#2 |
Did it Himself
I would have thought that this would only apply to a switching circuit, e.g. comparator, as it is capable only of sinking current not sourcing.
#3 |
I guess you could do some sort of single ended thing, but why on earth would one want to?
A little more info on your intent or application maybe? |
#4 |
I simply can not understand how can npn output stage of an amplifier work without electrical conection (at least I`m not able to determine it using multimeter) from 1 (out of 4) transistor collectors to the rest of the circuit. But mesuring of the voltage (in working set up-sorce and loade on) show`s -45V on colector on that npn.
Marijan |
#5 |
Did it Himself
Ahh, now I see. It's very simple
![]() Basically, the other three transistors are doing the work so the amplifier will appear to be fine until you stress it. You are seeing -45V on the one transistor that is unconnected simply because it's emitter is connected to the -ve rail and the device is turning on = low resistance. |
#6 |
Thanks Richie. I draw a quick skatch but I`m not shure, does it make any sense. All npn`s out.
| Why collector/drain output stages are so rare??? | Leolabs | Solid State | 67 | 3rd September 2011 10:37 AM |
| Unbalance Collector Emitter voltage both pnp and npn | EMX_125 | Solid State | 1 | 18th May 2010 04:30 PM |
| What is the capacitor from base to collector for? | EE | Solid State | 8 | 23rd May 2009 03:05 AM |
| NPN negative collector resistance?? | darkfenriz | Parts | 7 | 16th September 2007 06:45 PM |
| Question about output stage used in open loop | Banfi T. | Solid State | 31 | 4th May 2004 04:21 PM |
| Page generated in 0.09848 seconds (63.32% PHP - 36.68% MySQL) with 11 queries |
