Old 14th January 2005, 01:24 PM   #11
jaycee is offline jaycee  United Kingdom
If you want something different, I have also seen a TL431 used as a vbe device, with a string of diode-connected transistors for thermal tracking. Look at the Stochino amplifier for an example
BTW you can get at least one TL431 for free from a dead PC PSU. I have a stack of them.
Old 14th January 2005, 01:31 PM   #12
hienrich's Avatar
Default do you have schemes for this
jaycee:
hi do you have schemes for this.
hienrich
Old 14th January 2005, 01:43 PM   #13
Here it is:
http://www.soton.ac.uk/~apm3/diyaudi...no_circuit.jpg
I just tried this TL431 in my triple darlington amp SPICE sim (similar to the Leach Amp) and found it to be a bit tricky to control. Maybe a simple Darlington VBE would be best.
Old 14th January 2005, 01:59 PM   #14
hienrich's Avatar
Talking thanks I got it....
thanks Jaycee,
I got it I on to it now.
hienrich
offline........
Old 14th January 2005, 02:14 PM   #15
Jennice is offline Jennice  Denmark
Heinrich,
When I sent my first reply, I didn't have time up open your schematic.
Therefore I didn't know that you were already using a capacitor. I am using a 100uF in mine, and it works well for me.
I don't see a need for the film too, as the frequencies are low. They're more relevant for HF problems, I think.
Who says your transistor needs to be on the PCB, and you need to redesign your PCB???
I have mine connected to the PCB with wires. Who cares - it's just a DC source with floating potential, so you won't have to worry about inductances in the wires and HF problems with the Vbe multiplier / thermal monitor.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 14th January 2005, 02:17 PM   #16
Did it Himself
richie00boy's Avatar
Jennice, your assumptions are not correct according to Leach. See his website.
Old 14th January 2005, 02:31 PM   #17
Which part of my assumptions?
Old 14th January 2005, 02:52 PM   #18
Did it Himself
That bit. It's not just a DC source with floating potential because it's in the path of the VAS which is subject to AC and is sensitive to capacitance.
Old 14th January 2005, 03:04 PM   #19
And who tells you thet one cannot have a DC source in an AC path? It just gives an offset.
I know the Vbe isn't an idea DC source with zero output impedance, but that's why the capacitor is placed on the PCB.
Jennice
Old 14th January 2005, 03:16 PM   #20
Cortez is offline Cortez  Hungary
Cortez's Avatar
When optimizing, go for Lowest 3rd harmonics .. not THD!! lineup Solid State 221 6th February 2009 06:43 AM
optimizing for efficiency Dwiel Solid State 13 10th May 2005 09:31 PM
Optimizing bass response in Zen 4 Buhl Pass Labs 10 10th March 2005 08:55 PM
Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC? dieringe Digital Source 59 14th October 2004 03:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
