Pictures of my almost-built preamp... - Page 3 - diyAudio
Old 5th August 2002, 11:28 AM   #21
Guido - just seen your other reply...
Ferguson used to do that in their TX100 range of TV sets! They had an IR tx IC mounted on the same PCB as the IR reciever/preamp circuit. To get the signal from the local IR TX IC, they put an IR LED on this same PCB, close to the IR reciever diode!
There is just one minor problem that I've noted with this - the front panel buttons aren't very responsive because of the 1/4 second transmit/decode time...
Also, I agree about the extra clock. That's why I didn't like the idea of using conventional multiplexed switches. The VFD is mounted behind a decent chunk of aluminium, so I'm hoping that any noise generated is largely contained...
Thanks again
Cello preamp pictures ANALOG GUY Solid State 40 12th March 2015 10:45 PM
Know of an ADC with Built-in Preamp / Electret Bias? snickell Chip Amps 0 6th June 2008 09:13 AM
i want to built new preamp maxpou Solid State 8 1st January 2008 08:11 AM
Sound car with mic preamp built in? andy2 Multi-Way 3 5th February 2007 02:24 PM
Preamp pictures. jim Tubes / Valves 12 2nd July 2003 03:31 PM
Copyright 1999-2017 diyAudio
