Pictures of my almost-built preamp...
Old 4th August 2002, 10:33 PM   #11
guido is offline guido  Netherlands
guido's Avatar
Mark,
Have some routines to have a pic (i'm using a 16f84) talking to a 24c02. Probably got them from the net somewhere. I'm using i2c for all communication, so only 2 lines are needed.
Drop me a mail if your interested. Maybe have a look at my site.
Like your PCB's, must have taken you a while to design.
Greetings,
Guido
GuidoB
Old 4th August 2002, 11:06 PM   #12
mhennessy is offline mhennessy  United Kingdom
Hi Guido,
Thanks for the offer. It's definately something I'd be interested in, although for this project I'm using the PIC's internal EEPROM (one day!)
I'd found your site just recently - very interesting. I like the idea of using a state-machine for the RC5 decode - not something I'd considered. How good is it? In terms of errors and responding to the wrong remotes, I mean. Mine is quite different to yours - it's not as clever - but it's proved to be quite reliable...
Before anyone asks, I'm not quite ready to release it to the world yet! It's still "my baby"
You're right, I spent ages on the PCBs. I quite enjoy it, I'm afraid! The main analogue PCB went through several drafts until I got something that looked nice, incorporated everything I needed, and felt electrically 'good'.
Spent all day on the software again, this time chasing silly little bugs The 80/20 rule definately applies here!
Listening tests soon, I promise!
Old 4th August 2002, 11:48 PM   #13
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Mark,
Where did you get your hands on the Noritake VFD, and how much did it cost? I've been trying to find a supplier for some time now...
Very nice job on the project! The PGA2310 looks like a real nice part... I'll be keeping my eye out for your listening results.
- Chad.
Old 5th August 2002, 12:22 AM   #14
Hi hifiZen
I bought the display from Farnell for around 40 UK pounds. Check http://www.farnell.co.uk/
Shame the graphics displays are so expensive
Old 5th August 2002, 01:03 AM   #15
hifiZen's Avatar
Tell me about it... although 40 pounds isn't sooo bad for a VFD. If you want graphics display though, get ready to break the bank!
I've had decent luck finding surplus LCD screens for cheap, but for a top-notch project like this, you really do want to have a nice display. You have to be careful with VFDs though, as there seems to be a lot of quality variation amongst them. If you compare a Sony front panel display with something like a cheapo Apex unit, you'll see what I mean (Sony knows where to put it's money - aesthetics). Good VFDs are bright and crisp, and evenly lit across all the pixels. Bad VFDs are generally dimmer and you can see brightness gradients across the display (which also appear as sharpness gradients - yuk). I think Noritake is one of the best brands available however, so you shouldn't have any trouble with this display.
Can't wait to see some pics of the finished product! My vote: go for the custom case. You'll thank yourself later!
PS - Thanks for the info.
- Chad.
Old 5th August 2002, 01:09 AM   #16
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Pictures of my almost-built preamp... Send a message via AIM to Peter Daniel
Yeah, go for a custom case. See what I meant good, old days. No displays then thou.
http://www.diyaudio.com/forums/showt...2&pagenumber=1
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th August 2002, 11:37 AM   #17
guido's Avatar
Mark,
The RC5 routine i am using works very well (i did not invent it, only migrated the code from 8051 to pic).
No problems at all with decoding RC5. I don't know of interference problems with non-RC5 remotes, i only have equipment with RC5 at this moment (TV,CD player, preamp).
I expect no problems though !
One thing i should mention. It assumes the pic is in sleepmode. When the code is received, the thing is woken up via the interrupt pin. Since it needs some time to start up properly, the first received RC5 frame is disgarded and it decodes the second coming in. Somebody using the code reported that his remote only sent one string when the key was pressed very shortly.
So then it wakes up, but does nothing until another keypress: it is waiting for the second frame, but will decode the first frame of another keypress.
I don't seem to have this problem, since i am using a (philips) programmable remote, which seems to always send out more than one frame when a key is pressed.
I started with an integrated SH505 or SH506 RC5 decoder with lense, but now i am using a receiver module from a TV (3047 or 3048 inside). This works MUCH better !!
Greetings,
Guido
GuidoB
Old 5th August 2002, 11:47 AM   #18
Hoffmeyer is offline Hoffmeyer  Denmark
Looks really GOOD.
Hoffmeyer ;0)
Old 5th August 2002, 11:51 AM   #19
guido's Avatar
One other 'trick' if you have keys on the front of your case (i don't have any keys, only using the remote):
Get an old RC5 remote control and take it apart. Take the chip inside (no SMD is better, i guess) and put it in your own design!
You can take the output and connect it (somehow: OR port or transistor to pull the line low, depends on the receiver and the retrieved chip), to the connection between the RC5 receiver and the pic.
Hook up the keys on your front with the same code as sent by the remote and voila, you can read the keys on the front with no changes to your programming! The pic won't see the difference between front keys and remote. Also you don't need additional pins and interrupts.
Seen this done in my Meridian (202?) preamp..
The disadvantage is that the RC5 transmitter chip has it's own clock, which is then running all the time.. That is also the reason i did not put in a display, also has a clock which is switched on continuously.
Greetings again,
Guido
GuidoB
Old 5th August 2002, 12:01 PM   #20
Peter Daniel: That was the thread that got me thinking about a custom-case! I'm very jealous of your aluminium skills - I'm sure I'll have lots of questions for you in the future
Guido: Thanks for the info. I decided againsts using sleep because, as you say, it does cause a lack of responsiveness. Philips remotes auto-repeat, but you do have to hold the key for a good half-second....
It's definately worth trying some non-Philips remotes - I found that some of them caused spurious codes to be generated. Something else that caused me trouble: florescent lighting. When I installed the recessed lighting in the workshop, my RC-5 code turned into a random number generator! Thankfully, all of these problems have been fixed now.
The RC5 code was one of my first bits of code that I wrote for the PIC. Now that I'm much more experienced with PIC programming, I intended to revisit the code to see if I can improve it. I will be thinking about your method very carefully. Thanks for your input
Pictures of my almost-built preamp...Hide this!Advertise here!
Cello preamp pictures ANALOG GUY Solid State 40 12th March 2015 11:45 PM
Know of an ADC with Built-in Preamp / Electret Bias? snickell Chip Amps 0 6th June 2008 10:13 AM
i want to built new preamp maxpou Solid State 8 1st January 2008 09:11 AM
Sound car with mic preamp built in? andy2 Multi-Way 3 5th February 2007 03:24 PM
Preamp pictures. jim Tubes / Valves 12 2nd July 2003 04:31 PM
Copyright ©1999-2017 diyAudio
