Has anybody used the MJ10022/23 transistors for the outputs on a Leach amp?
#2 |
From the data sheet:
MJ10022 : 40 AMPERE NPN SILICON POWER DARLINGTON TRANSISTORS 350 AND 400 VOLTS 250 WATTS Why would anybody "want" to use these in a Leach amp? Prosit
Two people can keep a secret if one of them is dead. |
#3 |
That's a big NO !
This transistor was designed for switching. Did you look at SOA ? 0.3Ampere at 100volts, there are really better devices ! Also, this transistor seems to be no longer in production. |
#4 |
Whoops! I typed the wrong numbers. They should have been MJ15022/MJ15023. Sorry.
#5 | |
sajti |
#6 |
Or use the mj15024/25, this one is often used in many applications,
as it's been prooven to be very robust. Ampslabs use these throughout their bipolar amps. |
| leach amp output problem | squarehdca | Solid State | 6 | 8th February 2005 09:28 PM |
| dc on output of leach | Wagener | Solid State | 9 | 7th August 2004 05:05 PM |
| Leach - mixing Power Transistors | Arco | Solid State | 7 | 15th August 2003 07:12 PM |
| Replacement transistors for leach amp | Bosium | Solid State | 12 | 13th June 2003 09:07 AM |
| Leach amp transistors | supernet | Solid State | 11 | 12th March 2003 10:52 PM |
| Page generated in 0.08554 seconds (65.57% PHP - 34.43% MySQL) with 10 queries |
