Old 10th January 2005, 08:27 AM   #1
4real is offline 4real  Netherlands
Send a message via ICQ to 4real Send a message via MSN to 4real
Default Class A dilemma
Well, here is the thing:
I want to use a Class A amp with my ribbon tweeter in an active speaker setup (and a LM3886 for thewoofers).
So I'm looking for a Class A design that is fairly simple, and can produce about 10 W into 6 Ohms. And of cource, it should sound fantastic! The problem is that most designs produce a little more power, and that would mean that the amps would produce an bit of extra waste heat (I know they do that anyway, but it gets worse with more power ).
I found these designs:
- http://www.tcaas.btinternet.co.uk/index-1.htm
- http://sound.westhost.com/project3b.htm
- http://sound.westhost.com/project36.htm
- http://www.passdiy.com/
Now the big question: which one to choose. Since it is used with a ribbon the amp should be able to amplify upto at least 20 Khz flat. How do they compare? Which one sound best? Which one can be used at a lower voltage, and at what voltage..., to get less power output (I understand that not all amps work will at lower voltages). 10W is more that engough for a 94 dB ribbon that is used from 3.5 Khz.
Any other nice designs are of cource welcome!
Old 10th January 2005, 09:24 AM   #2
destroyer X's Avatar
Default Death of Zen, Mr. Rodd Eliott amplifier will be good enougth
Take a look in ESP pages.
regards
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 10th January 2005, 09:38 AM   #3
Default I was thinking and laughing alone as a crazy one... i may be!
Thinking about your dilemma....hehe...this is the worst place on earth to clear dilemma.
Each one have it's own idea related what is good and what is bad...some will came with instruments...other with circuitation...technologie...and you will have 360 ways to go....
Your dilemma will be multiplied, you will kick your amplifier and will go to another hobby.
Here.... when entered i was ignorant and had no dilemma...now i am full of culture...and have hundred dilemmas.
regards,
Carlos
Old 10th January 2005, 10:18 AM   #4
EchoWars's Avatar
Just got done building Rod Elliot's DoZ amp...other than the fact that it gets too hot (because the voltage is about 44.5V) and that I have transformer shielding issues, it is quite good sounding.
Old 10th January 2005, 10:33 AM   #5
You could also build a Zen amplifier or mini Aleph.
Try the Pass Labs section.
There are quite a few people who can help you.
Still in the learning proces.
Old 10th January 2005, 11:06 AM   #6
Default Try something real cheap
For a tweeter, you owe it to yourself to try the Sonic Impact T amp. They are 19.95 right now. They will put out about 7 - 8 watts into 6 ohms, generate no heat, and run off batteries.
I just had to try a couple, and find the highs are extremely good. The sound was a big surprise. They sound better than some of the amps I own when used on my horns. I do not think they will work with normal full range speakers.
Buy a couple, the dc offset varies a lot, the two I have range 20 - 100 mv. Use the pair with the lowest offset.
But they are not Class A.
George
Old 10th January 2005, 11:20 AM   #7
Default I will not put doubts on you...as you can reduce heat and power of the DOZ
Go to DOZ...will be cheap and good enougth.
others are good...but will confuse your mind...they are many!
regards,
Carlos
Old 10th January 2005, 03:01 PM   #8
Default Re: I will not put doubts on you...as you can reduce heat and power of the DOZ
regards,
Carlos
Haha, what is a life without a confused mind... It is darn dull if you ask me. So more delemma's is not always a bad thing . It is even more fun confusing other peoples minds
I am also more interested in the technical possibilities. I saw that the pass amps have a not so verry good high frequence response (just upto 16 Khz), or am I wrong. The other thing is the power output. Since most amps give more power, I want to lower the voltage, but upto what voltage can I use the amps without getting unstable?
Old 10th January 2005, 03:14 PM   #9
Rudy is offline Rudy  Belgium
Thats depending on the topology off the amp in question.
Rudy
Old 10th January 2005, 04:26 PM   #10
Rudy
Sure, that is exactly why I'm asking about it! What is the best topology in my case ?
My dilemma Vivek Solid State 16 13th July 2009 01:12 PM
DIY dilemma, TMM, MTM or TMW Dave Bullet Multi-Way 30 11th May 2007 01:56 AM
Dilemma Arne Multi-Way 3 30th January 2006 09:46 PM
Amp dilemma AuroraB Pass Labs 6 22nd September 2003 04:04 PM
Page generated in 0.16370 seconds (63.45% PHP - 36.55% MySQL) with 11 queries
