Old 9th January 2005, 09:30 PM   #1
Send a message via AIM to Mach_Y
Default help with input pot please
Hello,
I have an Alps dual 20k pot (21 click version) on the input of one of my amps. After the 5th turn, the volume no longer increases. I have it simply hooked up as input signal to the pot, ground to ground, and the other pin to the input stage of the amp. Is there something I can do to pad it down so to speak so that I must turn the pot through all 21 turns to reach full volume?
Thanks!
Mark
DIY of course
Old 11th January 2005, 07:15 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I'm not sure if I understand your hook up correctly?
I should be like this:
Input
|--- to amp (center pin)
Gnd
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 11th January 2005, 07:17 PM   #3
Jan Dupont's Avatar
I have deleted this reply with purpose
Old 11th January 2005, 07:24 PM   #4
markp is offline markp  United States
Is it linear or audio taper?
If it sounds good... it is good!
Old 15th January 2005, 04:24 AM   #5
It appears to be a linear Any fix for that? (besides getting the right pot to begin with)
DIY of course
Old 15th January 2005, 05:04 AM   #6
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Search the forums for: Law faking or law-faking
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
Class D input LM311 Inverting input zox2003 Class D 1 1st February 2008 07:48 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
convert Quad44 radio input to CD input jives11 Solid State 11 5th March 2005 02:33 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
Page generated in 0.15783 seconds (42.76% PHP - 57.24% MySQL) with 10 queries
