Old 6th January 2005, 05:47 PM   #1
Default dvd player tweaking hurdles
I've got a panasonic s35 that I bought with the intention of tweaking. I'm fairly new to this hobby, so am just trying to get the ball rolling. First thing I did was to take off the cover to see what I am able to get at. It looks accessible at first glance, but when I start removing screws I see things are a bit more interconnected than I first thought and that I may not be able to get the PCB out to work on it.
How do people usually deal with this scenario? I have thought of taking a Dremel to the bottom of the case to allow access to the bottom side of the circuit board. Is this commonly done? I am just wanting to replace the PS caps first. I don't know what to look for when considering replacing the clock, etc.
Old 7th January 2005, 06:50 AM   #2
gaincell's Avatar
timsch75, "DON'T DO IT"! First of all, even if you suceed at completing
the mod., you will regret canabalizing the case. But then,
maybe you won't. However, one thing is almost certain, you
will have metal shavings "throughout" the PCB. And there is
a good chance that you will hack a solder run or, connection
somewhere and maybe never know it. My advice would be
for you to take alittle more time to study the assembly and
the approach may just come to you..
Old 7th January 2005, 02:22 PM   #3
Sounds like good advice. I have been looking for ways to get at the board. It looks quite simple, but it just hasn't come apart for me yet, and I don't want to force things as some of the components look fairly delicate. I wish I had my digital camera to take some pics of the problem areas so that someone might recognize a problem they've overcome, but the wife has it in CO
Old 7th January 2005, 02:26 PM   #4
Hello,
The people who built your unit had to get the PCB in some how.....it will also come out.
You may have to remove the transport first. You also may have to remove the face of the DVD player.
KevinLee
Old 7th January 2005, 03:19 PM   #5
I tried removing the face yesterday. The connection of the PCB in question with the face is the last connection I need to undo. However, the face was connected to other componens in ways I couldn't quite figure out. This is where I decided not to force it. I'll look at it again this morning.
Old 7th January 2005, 03:29 PM   #6
Hi again,
There should be a ribbon cable that is attached between the face pcb and the main pcb.
This ribbon cable is connected to the main pcb with a connector that has a 'clip' feature to it......have a close look and you should be able to figure it out.
You have to pop up the retainer on the connector to remove ribbon cable....just do the reverse when re-installing.
Cheers
KevinLee
Old 7th January 2005, 05:02 PM   #7
I can get the ribbon cable out of its connector. The cable itself just slides into a connector. The piece I'm having trouble with is a small black connector located just to the left of where the ribbon attaches to the face (viewed from the rear). It looks alot like the front grill of a jeep
Really cheap player for tweaking and experimenting. Zero One Digital Source 0 20th August 2006 02:27 PM
what CD buy for tweaking? LennyK Digital Source 0 29th July 2005 08:50 AM
Help with car amp tweaking sq_guy Car Audio 15 7th May 2005 04:14 AM
tweaking Sony C222ES SACD player dorkus Digital Source 3 10th December 2002 11:30 PM
Page generated in 0.09338 seconds (77.72% PHP - 22.28% MySQL) with 10 queries
