Old 6th January 2005, 01:43 PM   #1
Mlaen is offline Mlaen  Croatia
Default 25W MOSFET amp problem :(
It's me again, ,with the same amp and simisliar problem...
I've finished constructing the amp (new one) and when I connect ampermeter in series with Q8 drain and turn it on fuses, R16, R13 and Q6,7,8,9 blows!
I have checked PCB many times but I found no errors, I don't know where to start search for mistake...
You can find the amp at http://www.electronics-lab.com/proje...001/index.html
Any help is welcome! Thanx!
.::Mlaen::.
Old 6th January 2005, 02:59 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Maybe there is something wrong with your powersupply ?
Old 6th January 2005, 03:14 PM   #3
When I messure it output is -+36V
I think PS is OK
.::Mlaen::.
Old 6th January 2005, 03:52 PM   #4
MikeB's Avatar
Can you post pictures of the assembled amp ?
The schematic looks fine and uncomplicated.
R10&12 also should have burned, if not, there is something
very wrong !
Old 6th January 2005, 04:35 PM   #5
richwalters's Avatar
Now the nasty ones...ehh... This isn't easy following it through without having the board in front of me-.I'm suprised there isn't a resistor somewhere in current path to Q2.....R4/R5 are they correct ? if not, then there's an unlimited current path from + to 0v. Same applies for R9/10... Q5/6.
Has R11 got badly soldered joint? Is it o/c ? Obviously check all semiconductors are the correct way round. If you do find one wrong......replace with new ones. While you are about it, just check C9 polystyrene cap for s/c......you might have branded it with the soldering iron. This wouldn't be the cause of the problem.
rich
Old 6th January 2005, 05:20 PM   #6
Send a message via Yahoo to psychosteve
i know it sounds silly but i had a problem similar to this,
it turned out that the amp meter i was using had a feeder circuit in line with the current sense. and it was the amp meter changing the circuit that made every thing blow. some thing about inductive windings???? dont ask me, i dont know why.
if your setting up the circuit for the first time, setting bias current?, have you used a smaller power supply, or small batterys, or put resistors inline with the power supply to make sure that the circuit is correct, before you try to sett every thing?
see you soon, steve.. ..
you all laugh because im different, i laugh because youre all the same.. ..
Old 6th January 2005, 05:29 PM   #7
should quincent current, for bias setting be measured on the power line into the amp, ..... not inline with Q8????
i dont know much, but all the amps ive ever built have a fuse, and the setting is done with a amp meter in series with the fuse...
but then what do i know, see you soon, steve.. ..
Old 6th January 2005, 05:34 PM   #8
Rahul is offline Rahul  India
Send a message via Yahoo to Rahul
Hi!
My personal experiance P ch FETs are not very regular consumer components in comparison to N Ch FETs. Possibly the trouble may lie with the N ch FET alone.
Seeing you are interested in N Ch FET designs I made a single sided bord for the Pass Mod for HK Ciatation 12.
You may download the artwork from:
citation 12
It is not the ultimate but nevertheless it is a very good for price to performance ratio. The layout has been tested many times over. ( Boards were free for asking for Indians DIYers)
Rahul
We can make it work
Old 6th January 2005, 05:36 PM   #9
N ch FET alone
Kindly read it a Pch trouble . N Ch are more abundunt.
Rahul
We can make it work
Old 6th January 2005, 05:47 PM   #10
MikeB's Avatar
I never had any problems with P-channel hexfets from IR.
problem with heat of MOSFET yanuarbob5150 Class D 8 9th February 2009 03:11 PM
Mosfet Power Amp Problem Telnet100 Solid State 4 30th June 2007 04:12 PM
Simple MOSFET amp problem luixssj3 Solid State 26 9th October 2006 01:54 AM
Problem with mosfet amp JKLman Solid State 6 14th May 2002 11:42 AM
Page generated in 0.09984 seconds (85.12% PHP - 14.88% MySQL) with 11 queries
