Old 6th January 2005, 10:23 AM   #1
djdamix is offline djdamix  France
Default stability
I'm developping an amp which sounds ok, but I am wandering
1)how I can test its stability ?
2)Why do people use zobel network on the output (I mean L & C )
3)How does it increases stability ?
David
Old 6th January 2005, 01:56 PM   #2
Mr Evil is offline Mr Evil  United Kingdom
1) Depends on how unstable the amp is. If it's very unstable then it will be obvious, with the output oscillating at a particular frequency, usually causing heating of the output devices. If it's marginally stable then you may see bursts of oscillation. An oscilloscope is indispensable here.
A good test is to put a square wave into the amp and look for ringing at the output. If there is no ringing then the amp should be perfectly stable. A lot of ringing and you have a problem. You may want to test for stability with a capacitive load too.
2) For stability of course. BTW, you mean R + C at the output. If there's an L then it's not part of the Zobel network, although still there for stability.
3) It provides a low impedance path to ground at high frequencies. This helps compensate for the rising output impedance of the amp at high frequencies and/or inductive loads.
https://mrevil.asvachin.eu/
Old 7th January 2005, 01:25 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Don't forget to run it untill it's quite warm and redo your tests. Things can change with temperature.
-Chris
Old 7th January 2005, 07:30 AM   #4
good idea! I'll try
testing for stability maxpou Solid State 70 24th March 2012 08:09 PM
Amp stability unclear Khron Solid State 30 3rd April 2009 06:45 AM
Stability TA2020 and T-Amp opentop Class D 2 18th May 2005 02:51 PM
LF357 stability richwalters Chip Amps 3 15th March 2005 05:38 AM
Page generated in 0.08083 seconds (73.47% PHP - 26.53% MySQL) with 10 queries
