Old 3rd January 2005, 11:50 AM   #1
NUTTTR is offline NUTTTR  Australia
Default Adding pre-outs into a processor with separate internal amp?
Ok,
Maybe this has been done before (and every time i know what people have answered!!!) however i consider this one a little different!
My H/K home theature amp has essentially "power amps" inside it, i mean they are connected to the mainboards, but only for power, the actual audio connections are made to the board by leads directly from the processors outputs!
If i d/c these leads (there's one for centre and 2 for the mains) there's no sound at all, it sounds simple enough for me to simply drill some holes, mount terminals and plug these in, however, i don't want to simply do that, because it sounds too simple - i am SURE that i have to use a cap on the "sheilding" to the earth, and obviously test the outputs of the "preouts" to make sure it's not driving stupid voltages out of them!!! Is there anything else i should really check for? I've had an amp that had it's rca's not electrically isolated from the main power supply (somehow hooking up this amp to another amp from a different manufacturer it blew up in sparks!), so i'm making sure that there's not trap i can fall in, seems easy to me and simple, but is there a catch? I will totally disconnect them from the main power amp inside the unit, i don't need, nor want, to use it again, and if i do, i'll simply open it up, and plug the wires back in, simple!
Anyway - any advise? Cheers!
Aaron
Help with driver cut outs st_eloi Multi-Way 0 12th May 2008 08:50 PM
adding pre-outs to an inexpensive HT receiver. montreal Digital Source 39 3rd May 2007 01:15 PM
Help! Adding separate tranny in CD723/CD4000 binatang Digital Source 7 16th September 2006 11:47 AM
PC3-08 Pin outs Wynand Car Audio 0 18th May 2005 08:33 AM
ins and outs set Subwoofers 7 16th February 2005 01:31 AM
Page generated in 0.17390 seconds (85.79% PHP - 14.21% MySQL) with 10 queries
