I have a NAD 2200 that has blown, I took it in for repair, the Voltage selector has blown and is I am told no longer available, i need to replace this to trace the further problems, the unit was hard wired to see if it would power-up, but no response, anyone know of a source for this part?
#2 |
Hi erdebear,
Check for continuity on the primary. The thermal fuse may have opened. After that you can just hard wire the voltage selector. -Chris |
#3 |
Thank you, does anyone have a schematic or a source of one, this is a fine amp and would like to have it back working again!!
#4 |
Banned
How did you blow it up ? I tried for years to blow mine up but just couldn't ? i got it for free and re-paired it after some kid left there peanut butter sand-witch on it and blew the one channel i fixed it and loved it major work hours amp.
#5 |
Another sandwich ??
Sorry, couldn't resist. You should see how many people blow up their amp with the owners manual! (on top) -Chris |
#6 |
Sorry for the delay, I could not get on the site again!! i had not used the amp for a while, I turned it on, but no power, so i opened it up to look for a blown fuse, but found them OK, I saw that the voltage selector looked loose, the top of it was not flush with the holder, i checked and it lifted out of the body and the connectors looked scorched. I put it back in, lined up with the 240v mark, powered it up, and the light came on for a second or two, and then phut, the voltage selector flashed. I do not have enough tecnical know-how to go much further, i took it into a repair shop, who could not get a replacment selector, they hard-wired it and said it was still dead, and as the part was not available, it was not an economic repair, so I have it back. so do not quite know what to do with it now? As I said its a great amp and I miss it. i replaced it with an Arcam 290 pre/power combo, though the integrated/pre was blown when i bought it, I had it repaired, two input transistors, and it has blown again recently, so now have the Nad 1155 pre and arcam 290 power. Does anyone know if this a weakness on the 290P integrated/Pre amp?
Thanks anyhow. |
#7 |
Banned
hey it was free along with my yamaha AX-930 my yamaha costed me 20$ to fix and the nad was 40$ and my 2 poweramps Inkel 1500 watters blew up costed me less than a dollar because it as a simple transister : O )
| Parasound HCA-2200 II repair question | cocolino | Solid State | 10 | 6th September 2008 07:45 AM |
| PPI PCX-2200 connectors needed | skooter | Car Audio | 2 | 25th November 2007 02:31 AM |
| PPI PCX-2200 manual needed | skooter | Car Audio | 4 | 24th November 2007 12:27 PM |
| 2200 uf 6.3 v Black gate for 2200 uf 16 vdc | max29 | Analog Line Level | 7 | 7th November 2007 08:51 AM |
| NAD 2200 power supplay help needed | cypher | Solid State | 16 | 31st March 2007 09:40 PM |
| Page generated in 0.08522 seconds (75.39% PHP - 24.61% MySQL) with 10 queries |
