Old 1st January 2005, 11:19 PM   #1
Rjones5296's Avatar
Send a message via AIM to Rjones5296
Default Replacement driver boards for the Quad 303
Looking for replacement driver boards for the Quad 303 amplifier. There was a seller on Ebay that was sellling replacement amp driver boards but I can't remember his handle. I have recently bought a 303 that is a disaster, the circuit boards are in pretty bad shape. I could also use a heatsink for the outputs as mine was damaged in shipping.
john
Old 1st January 2005, 11:31 PM   #2
hifi is offline hifi  Sweden
I got the service manual somewhere if you would care to roll your own.
/ mikael
Old 5th January 2005, 09:52 AM   #3
I'm in the middle of repairing a 303 for a friend - power regulator dead (putting 84volts on rails), one channel dead (blown bias transistor, dead output transistors, tracks blown off pcb, etc.).
I'm wondering whether you'd be able to advise the correct method of setting the bias current - this is the later design with the active bias control.
Thanks.
Old 6th January 2005, 09:38 AM   #4
I recently acquired a Quad 303 and would be very interested in the Service manual.. Could you send it to me?
tschrama@fsw.leidenuniv.nl
kind regards,
thijs
Old 7th January 2005, 03:09 PM   #5
pete.a is offline pete.a  United Kingdom
pete.a's Avatar
Smile New Driver Boards
Hi Everyone,
Hope this helps with upgrading 303's
http://www.net-audio.co.uk
I think this was the stuff being sold on ebay, but this is the main man for upgrading Quad's anyway.
These are good amps, i started back up with bi-amped 303's. Didn't do much more than change the main smoothing caps, as they had past their best.
Dont have them now though as sounded a bit warm and wooly with my IPL S3tlm's.. there really suited for ESL 63's, but im sure if the right parts are changed they can compete with some of todays amps.
Now use Williams Hart mono blocks
PPI driver boards Perry Babin Car Audio 2 23rd February 2009 04:18 AM
quad 303 pcb -- direct replacement / modification bigpanda Swap Meet 1 2nd October 2008 05:48 AM
Quad II tubes replacement assimaki Tubes / Valves 0 28th June 2008 09:10 AM
hafler pc 19 driver boards eyoung Swap Meet 0 28th October 2007 05:32 PM
Dyna Mk IV Driver Boards DDF Tubes / Valves 1 3rd January 2005 11:27 AM
Page generated in 0.07678 seconds (71.92% PHP - 28.08% MySQL) with 10 queries
