"Optimum" Class B better than Class AB?
Old 31st March 2003, 11:46 PM   #51
AMPMAN is offline AMPMAN
Default ca pslock
yes thats the one
RW
Old 2nd April 2003, 06:29 AM   #52
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Default to capslock
I cannot sent a paper to you until will get your answer on my private message with your email
Old 4th April 2003, 02:47 AM   #53
Default sam jaywara
yes I did build the amp but I could only get one channel working inthe meantime I have concentrated on the aleph x.re the out put transistors,the authers have this to say,A problem with power transistors driven by a current source isthat there is no turn-off resistor for them.Under high-frequency,high-amplitude drive there will be a tendency for the effective bias current to rise dynamically.By useing HF power transistors with an ft of 80mhz, This bias current rise is reduced to 60% at 20khz at full drive.
RW
Old 4th April 2003, 03:38 AM   #54
Samuel Jayaraj is offline Samuel Jayaraj  India
Ampman,
I am aware of that comment, ie., the requirement for 80MHz transistors in order to keep the bias stable. But the 2SC3281(5200) and 2SA1302(1943) pair are only 30MHz devices. Hence, my question - was the amplifier stable in long term operation and what about the sonics?
Thanks,
Sam
Old 4th April 2003, 11:09 AM   #55
traderbam is online now traderbam  Europe
traderbam's Avatar
Ampman,
How big is this effect? Say the dc bias current is 50mA. If you then output 20KHz into 8 ohms, how much does the bias increase with, say, 30MHz ft transistors? How do you differentiate the bias increase due to slow turn-off effect from thermal changes? How much %change in effective bias matters?
Bam
Old 4th April 2003, 11:57 AM   #56
Default Bam and Sam
I'm afraid I cannot anwser your question's as I have'nt got astereo pair working and secondly I'm not an EE. anybody care to put mosfets on the output.
RW
Old 7th April 2003, 04:32 PM   #57
Ampman,
Don't worry about a STEREO version of the amp. That one channel that you have working, that is the one in question. Just let us know if the amp works stable for a relatively long time driving a nominal speaker load.
Thanks,
Sam
"Optimum" Class B better than Class AB?Hide this!Advertise here!
Difference betweeen Class D and "Digital Amplifiers" percy Class D 105 13th March 2007 03:03 AM
Schematic for Zetex "ZXCD500MOEVAL" - Class D Eval Board ? CAindoAUDIO Class D 1 16th November 2006 04:44 PM
Copyright ©1999-2017 diyAudio
