Old 31st December 2004, 09:46 PM   #1
Vesa is offline Vesa  Finland
Default Old MOSFET schema. Opinions?
Hi!
Yes, I'm very new here (my first post). Hope I fit in
What do you think about this amp. Desingn is quite old (but gold?). I was build one of these years ago, but then sold it after usin a few month. Now missing that thing.
Basic schema includes only one pair of FET's. I build it using 2 pair of them. More can be added. With two pairs of FET's and +/- 55V rails, amp produced 100W@8ohm and 200W@4ohm. With 500mA bias, amp working class A up to 1W.
What else can I tell.. Output devices are SK1058 and SJ162, if I remember right.
I was planning to make these kind of power amp again. I'm still confused, wich amp I choose. There's Leach, Krell-cone, Aleph's. I heard about Aleph first time in here. interesting "machine"
But can you experts tell me something this amp, that shema I post? Maybe build it again.. or not.
Old 31st December 2004, 10:01 PM   #2
johnnyx is offline johnnyx  United Kingdom
We cann't say anything without a schematic, we don't know what you're referring to.
Old 1st January 2005, 12:03 AM   #3
For some reason, my schema does'n show. Let's try again..
Old 1st January 2005, 12:03 AM   #4
I have also (naturally) pictures about that amp. Ihope, my files end up on board. As new member, I could not see my message immediately on the board.
Old 1st January 2005, 08:07 AM   #5
djk is offline djk
djk's Avatar
Your schema is a straight forward rip of a Hafler DH200/220/500
If you look at the Krell KSA50/100 schema you will notice they are the same except for the heavier drivers and BJT outputs.
The same cound be said for the:
Accuphase P300
Leach (a favorite of mine)
GAS Son of Ampzilla
Old 1st January 2005, 09:32 AM   #6
Looks fine to me too.. but a bit off topic... R6 R17... What's the function of these resistors...?
Happy building in 2005 ..
Thijs
Old 1st January 2005, 11:54 AM   #7
The doubling up of the zobel circuit seems a bit unusual R34/35 and C15/16.
What are the advantages?
regards Andrew T.
Old 1st January 2005, 02:33 PM   #8
Tube_Dude's Avatar
R16 and R17 equalize the voltage gain of T2,T6 with gain of T1,T5 by both "seeing" the some collector load resistor.
That way , the Miller capacity , will be similar in all the four transistors and the differentials will be more balanced in the high frequencies.
Cheers and a Happy New Year
Jorge
Old 1st January 2005, 03:25 PM   #9
These aforementioned schemas looks quite similar (topology) to me. Thaks. Maybe that's one reason, why I'm askin, after analyzing Krell's schematics and other similar. But I am not expert of amp circuit
I'd like to build Krell, Aleph or other "beast", but huge class A blocks.. They cost a fortune I think I need at least 50-60W, maybe 100W@8ohm (or more )
Do I hear differense between class A or B, Don't know.
R6, R17. I can't tell functions of these, sorry.
Happy new year to all !!
Old 1st January 2005, 04:13 PM   #10
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Well, this is almost a copy of the schematic in my hafler dh200 except for the CCS on each differential amplifier and a couple of other things including the outputs.
I find it's a pretty nice amp.
If you go to build it, I hope you have a chart of all the various resistor and part values
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Chearch schema DBX 386 studervox Parts 0 14th April 2008 03:06 PM
My SMPS schema jake83 Power Supplies 11 4th March 2007 03:26 AM
Hybrid amp schema? Ryssen Tubes / Valves 16 1st June 2006 03:30 PM
Mc 275 CE schema spoke Tubes / Valves 5 29th October 2005 12:35 PM
Schema NAD 310 fantomas Solid State 4 13th September 2005 05:50 AM
Page generated in 0.11976 seconds (73.16% PHP - 26.84% MySQL) with 11 queries
