Make your own temp. controlled iron
Old 31st December 2004, 05:31 AM   #1
murat is offline murat  United States
murat's Avatar
Default Make your own temp. controlled iron
Easy:
1) Buy a cheap lamp dimmer with rotary knob ($ 3-5 in stores)
2) Put it into simplest small box you can find around.
3) Play with it for a while and make your dial on the knob for different soldering jobs, tips etc. Wait long enough the temperature to stabilize for the first time while making your calibration. Now you have a temperature controlled soldering iron.
4) And the most important: Post your results here because I didn't try it yet.
Old 31st December 2004, 08:33 AM   #2
Enzo is offline Enzo  United States
Not quite. You have an adjustable power iron, but not temperature controlled. The point of temperature control is to maintain a certain temperature at the tip, not maintain a certain power level. if you solder the tiny leg of an IC to a pc board, it does not tax the tip very much at all, but if you solder a 16ga wire to a lug on a 35 amp bridge, it taxes the iron heavily.
Temperatrure control senses the heat output in some way and adjusts accordingly.
Old 31st December 2004, 01:20 PM   #3
lowlevel is offline lowlevel  Australia
not worth trying.
I tried this in the dim past & it wasn't worth it.
I have several temp controlled irons & have owned a variety in the past.
However I am impressed with the performance of some of the cheap non controlled irons.
Even the ones without electronic controll sort of self controll their tempriture due to the tempriture coeficient of their heater windings.
cheers
Old 31st December 2004, 01:36 PM   #4
jaycee is offline jaycee  United Kingdom
A friend of mine used to do this until he worked out it was shortening the life of the element. Normally the element vibrates to a sine wave which while stressful is nothing compared to it vibrating in tune to a half-sine half-square wave!
I did wonder how to measure temperature on the iron but I never thought of measuring it by the heater winding resistance. I may yet try something using one of Antex's 24V irons
Old 1st January 2005, 01:30 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
I am now using a temperature controlled iron I bought 10 yrs ago. It cost me $120.00 CDN at the time- with a digital temp display. I actually adjusted it until it was within 5 C across the useable range.
I now see these made-in-asia irons for less than $90.00 CDN. No excuse here guys. The non-digital display units are cheaper still.
These irons replaced a stable of constantly breaking temp controlled Wellers that cost me a lot more $$$.
Get an assortment of tips. I am still using the original! I like the wide screwdriver, especially on SMT stuff.
-Chris
Make your own temp. controlled ironHide this!Advertise here!
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 04:12 PM
how to make a remote-controlled 8ch attenuator? knutinh Everything Else 1 22nd August 2005 12:01 PM
Hakko 929 Temp Controlled Soldering Stations damonpip Swap Meet 49 8th May 2005 01:38 AM
is it possible to make solder flow on to 20awg solid copper with 25watt iron? travis Parts 13 24th June 2003 10:09 PM
Copyright ©1999-2017 diyAudio
