Here's what I am looking for:
A N channel power mosfet that is linear around 2A of Drain current and 40vdc supply voltage. Bias voltage 2-4 volts or so. will be running into a 64:8 Z transformer. So far: BUZ900P 2SK1529 2SK135 I think these are all lateral mosfets. IS there an IR part that could work? The attached image is of the output stage.
It is not you... you are it. |
#2 |
Or there is the Exicon EC10N16/20 which looks very promising.
Any data sheets for this? Thanks!
#3 |
Looking to do a variation of Jean Hiraga's Nemesis amp?
se |
#4 |
yes i am.
simulates good with a p channel buffer mosfet driving the n-channel stage. good for 12W RMS into 8 ohms. power supply thinking of: 33V/5A transformer 100v/50A bridge rectifier 2 50v/10,000uf caps 2mH air core inductor then 2 50v/10,000uf caps per channel The p-channel buffer will have its own pi filter taken from the above mentioned bridge. comments?
#5 |
The Exicon MOSFETs are nice. They do have datasheets on their website, although they contain limited data.
I have a spice model for ECF20N25 which you may find useful. Maybe not the exact one you're looking for, but they all behave similarly. Exicon will probably send you more data if you ask them. Code:
.SUBCKT ECF20N25 1 2 3 ********************************************** * Model Generated by PEDC * *Copyright(c) Power Electronics Design Centre* * All Rights Reserved * * Power Electronics Design Centre * * Dept of Elec & Electronic Engineering * * University of Wales Swansea * * Singleton Park * * Swansea SA2 8PP * * Tel : +44 (0)1792 295420 * * Fax : +44 (0)1792 295686 * * E-mail : pedc@swansea.ac.uk * ********************************************** * Model generated on Dec 9 1999 * MODEL FORMAT: SPICE Level 1 * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source * * * * O [1] * | * Z * Z Rd * Z * D2 | * Cdg0 |\ || [9] * |-||--| >|O---O-----|--------| * | [4]|/ || | | | * [2] Rg | ||---| Z --- __|__ * 0--/\/\/\/\-O----|| M1 Z / \D1 _____ * |[7] ||---| Z --- |Cds0 * | | Z | | * | Cgs0 | |RDS | | * |-----||--O---O-----|--------| * | [8] * | * O * | * Z * Z Rs * Z * | * O [3] M1 9 7 8 8 MM L=1 W=1 * Default values used in MM: * With the exception of Cgs0 the capacitances are * added externally * Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM NMOS LEVEL=1 IS=1e-32 CGSO=1.57e-9 +VTO=0.414 LAMBDA=0.104 KP=2.808 RS 8 3 0.191 D1 8 9 MD .MODEL MD D IS=1.0e-32 N=50 BV=250 +CJO=1.54e-9 VJ=0.633 M=0.479 RDS 8 9 1e+06 RD 9 1 0.289 RG 2 7 13.3 * Drain Source capacitance Cds0 CAP1 9 8 403e-12 ************************* * Gate Drain capacitance Cdg0 CAP 7 4 25.6e-12 ************************* * Gate Drain Capacitance Cdgj0 * Modelled as a diode D2 4 9 MDD .MODEL MDD D IS=1e-32 N=50 +CJO=137e-12 VJ=0.7 M=0.5 ************************* .ENDS
https://mrevil.asvachin.eu/ |
#6 | |
A Nemesis project seems fun, output transformers are a pretty good idea.
Ingvar |
#7 |
i tried that model... its way off what a 2SK135 or equiv would be.
the ECN 10N16 line is supposed to be like the 2SK135 or the 2SK1058... that is what I need.
#8 |
i don't think anything else will work... other mosfets get very non-linear around this operating point.
btw, whats the difference between the BUZ900 series and the Exicon 10N16 line??? the datasheets look identical.
#9 | ||
se |
#10 |
well... it will make driving it easier...
47K input impedance instead of 1K or so... improves HF response etc... also, by adjusting how much current i have through the P channel buffer... i may be able to have some distortion cancellation. hmm... 3 12V batteries per channel.... at least 10A/h they are pretty large and expensive. yes i have thought about it and have built a power follower (12v supply at 4.5A bias current)... best midrange i have EVER heard in a SS amp. anyways.... should 33vac be enough for a 40v supply at 2A?
| BiCMOS Bipolar+MOSFET better than MOSFET | lineup | Solid State | 5 | 8th December 2009 11:46 AM |
| amp selection | spicer81 | Car Audio | 20 | 23rd February 2008 03:04 PM |
| Sub selection | marcus555dc | Subwoofers | 5 | 14th February 2006 03:52 AM |
| Amp Selection | Donaldo | Car Audio | 4 | 25th November 2004 04:59 PM |
| depletion mode mosfet selection | svokke | Solid State | 0 | 17th May 2004 08:47 PM |
| Page generated in 0.13124 seconds (72.45% PHP - 27.55% MySQL) with 11 queries |
