STK 4392 Problem
STK 4392 Problem
Old 27th July 2002, 06:18 PM   #1
palesha is offline palesha  India
Default STK 4392 Problem
I made one amp with TDA 2030A with subout for PC. It worked well but it was very hot. Then i replaced the two TDA 2030a with STk 4392 with same tone control circuit. But now i don't get any low frequency from my speakers. I am getting the sound as if i am listening to only tweeter sound. I checked by replacing IC, giving direct input to IC STK 4392 but still the same sound. I am herewith attaching the circuit. If anybody has tried circuits of STK 4392 then please let me know. Hoping of sugggestions in the matter.
MP
Old 29th July 2002, 05:06 PM   #2
Problem solved. First we checked the amp made with TDA 2030a. After that we checked amp with STK4392. Here the sound was coming from tweeters. Hence first we doubted on the amp circuit. But after careful checking the woofers from the two way speaker system were blown. I am not able to understand how the speakers were blown away? There is no dc output at the speaker terminal. Any comments?
Mahendra Palesha
Old 31st July 2002, 05:37 PM   #3
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
us in STK465 is lower volt and high power out 30x2 in 0.08%
and low cost
and no will be a broblems
if u build right...
STK 4392 ProblemHide this!Advertise here!
dac problem kaldirdimgell Digital Source 11 13th December 2007 06:35 PM
Odd hum problem woody Tubes / Valves 2 29th October 2004 02:16 AM
Amp Problem definer Solid State 3 8th May 2004 11:04 PM
psu problem metebalci Tubes / Valves 11 25th April 2004 10:15 AM
Stk 4392 Datasheet palesha Solid State 3 16th July 2002 10:35 AM
