Where do you buy your components?
Old 27th December 2004, 04:22 AM   #1
kenle545 is offline kenle545  United States
Default Where do you buy your components?
I am about to build my first power amp, but I am having trouble finding parts at local stores such as Radio Shack and Fry's. Do you guys have a particular website that you buy all your parts from? Any recommended sites?
I found several "replacement" parts from fry's made by NTE. Do any of you have experiance with NTE products and should the replacements work fine?
Also, my gain stage contains a Vbe multiplier that uses a 1k Potentiometer. I bought a 1k Ohm Audio Taper/Switch Potentiometer from fry's. Should that be fine?
Thanks for any help.
Old 27th December 2004, 04:35 AM   #2
murat is offline murat  United States
murat's Avatar
Check:
www.digikey.com
www.mouser.com
I am not sure about the pot but usually 10k or higher is recommended.
Murat
Old 30th December 2004, 05:38 AM   #3
Enzo is online now Enzo  United States
Depending on what you do, look into some of these. I highly recommend ordering the paper catalogs from each. It is so much easier to browse a paper catalog to get an idea of what they have. Online is good when you know what you want.
Mouser is good and so is Digikey. I also use Allied for some things like power semis, but they have a stiffer minimum.
www.alliedelec.com
www.jameco.com is a hobby friendly place if more limited in selection. They also make the Jimpak line you might see in some stores.
MCM Electronics carries Japanese number series semiconductors and other general stuff www.mcminone.com
www.partsexpress.com has lots of speakers and speaker related stuff.
LOts of other places too.
Personally I avoid NTE and other "replacement" part vendors. I usually can get the "real" part cheaper and it will be exactly the part I want. Not only that, but if I mix NTE transistors with say Moto transistors ina power stage, I have no confidence they will share current evenly.
When I can buy a general purpose signal transistor like a 2N4401, 2N3904, MPSA06 or whatever for maybe 4 cents or 6 cents each, why would I buy the NTE part they say is equivalent?
Old 30th December 2004, 06:18 AM   #4
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
http://www.newark.com/ the same parent company as MCM, but with a different catalog. Good source of ASICs from Crystal Semiconductor and Analog Devices.
http://www.ampslab.com/ has some hard-to-find Japanese transistors
http://www.percyaudio.com/ carries audio specialty parts like binding posts, overpriced capacitors, and so forth.
Old 30th December 2004, 12:57 PM   #5
BobEllis is offline BobEllis  United States
BobEllis's Avatar
I'll add Arrow - http://www.arrow.com/ to the above list, although I primarily buy from Digikey and Mouser, sometimes Arrow has the parts I need when they don't.
As for your Vbe multiplier, you should be OK with the audio taper job, although adjustment may be touchy. A standard bournes trimpot at mouser runs about a buck, two bucks for a 10 turn type.
Where do you buy your components?Hide this!Advertise here!
NCD components rootbeer Class D 4 15th March 2009 05:09 PM
where to buy components dayking79 Solid State 4 6th February 2009 07:46 PM
What are these components? Mrpong Parts 4 15th January 2006 10:33 AM
components Swanic Parts 0 11th November 2004 10:00 AM
amp and components for a 911? jbrinkely Car Audio 2 23rd September 2004 01:18 PM
Copyright ©1999-2017 diyAudio
