This is only concept.
Any coments please... |
#2 | |
sajti |
#3 |
Right, but with class A (idle current 1.3A) much better results.
What spectrum of simulation?.. |
#4 |
I wouldn't use this in class AB with feedback
think about phase shift of a trafo- may cause hard to avoid oscilations in class A it is nice.. something like susan-parker's regards |
#5 | |
With this bias it will be class A, up to 25W/8ohms. The spectrum means low distortion, but the large 5th harmonic looks strange for me... Feedback can helps to reduce the distortion, but with interstage transformer You can't use more the 14-16dB without instability sajti |
#6 |
I have built a pair of power followers in the past that were designed by that guy in Italy.... can't rememhber his name. They sounded fine and were a good exercise in amp building but overall a waste of time. I would reccomend building one of the Aleph projects instead of wasting your time and money.
Mark |
#7 | |
#8 | |
sajti |
#9 |
Hi,so new struction of the circuit!
but the driver(transformer) is hard to DIY or Buy somewhere... if modify the circuit...same as JLH's output stage... I think many problems will not surv.
#10 |
Thanks to negative feedback, transformer in this circut is no so critical.Did have configuration 1:1:1.
Buy somewhere...http://www.jensen-transformers.com/d...s/123blcf1.pdf I will try to build amp with circut below |
| Class A power follower | jerluwoo | Solid State | 7 | 5th August 2009 05:48 PM |
| Comments please, on my class A follower | DRC | Solid State | 17 | 5th March 2007 08:41 PM |
| Class A2 SET using source follower driver | Audio_idiot | Tubes / Valves | 10 | 2nd December 2006 12:21 AM |
| Power follower class A Mosfet DC coupled. | Mr. Steve | Solid State | 30 | 15th February 2006 06:04 PM |
| Cathode follower Class A output stage? | Circlotron | Tubes / Valves | 14 | 15th May 2003 11:11 PM |
| Page generated in 0.11308 seconds (69.44% PHP - 30.56% MySQL) with 11 queries |
