Old 20th December 2004, 08:06 PM   #1
Default Newbie Question
Hi everyone,
For those of you annoyed by newbie questions, I'll steer you away now.
I am a speaker builder thus far. Recently however I have been looking into amplifiers, and have been wanted to create my own.
Looking over some designs and through some posts, I have a question: what is the specific use of capacitors in amplifier designs?
I understand how caps work and how and why they work in low-pass crossover circuits, but I don't understand how they can provide 'speaker protection' or how they can be useful in a power supply.
And my other question is, if transistors are the basis for a solid-state amp, then what is the rest of the stuff for (i.e. all the extra resistors, caps, etc.)?
Thanks in advance!
Reece
Old 21st December 2004, 03:37 AM   #2
jaycee is offline jaycee  United Kingdom
In a power supply, capacitors serve two primary functions - as filtering, and as energy resivoirs. The filtering is so that all the **** from turning AC into DC is filtered out and the voltage smoothed to more or less a constant level. As energy resivoirs, they supply huge amounts of current required to reproduce bass transients (which is why amplifiers with plenty of bass have large capacitors )
In a speaker protection circuit, they are normally used to form a low pass filter. Then a detector is set up to trip when a large amount of constant DC is detected, if it wasnt for the filter, your amp would cut out on low frequencies.
In an amplifier circuit they are typically used in 3 areas - DC blocking, bootstrapping, and "Miller compensation".
Old 21st December 2004, 03:07 PM   #3
PMA is offline PMA  Europe
PMA's Avatar
Default Re: Newbie Question
Originally posted by rjon17469
Hi everyone,
I also was not sure what they were for when I was about 12 years old. So I started to omitt them. Sometimes it worked, many times it did not work at all.
(Newbie) CSS Question bibster Tubes / Valves 8 24th January 2007 10:22 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
newbie question kambrian Multi-Way 5 28th December 2003 10:16 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.08123 seconds (64.34% PHP - 35.66% MySQL) with 10 queries
