Old 20th December 2004, 05:39 PM   #1
Unhappy Novice in need of help
I have a NAD 2100 PE that has a few problems. Uopn inspection the parts that are visually damaged are a transistor marked 7f C3423 and also parts marked Q426 and R436. Like I said I am a complete novice, and really am just looking at trying to save an amp that is other wise ruined. Anyhelp on where to get these parts or advice on how stupid I am to even consider trying to fix this??
Old 21st December 2004, 12:06 AM   #2
Stocker is offline Stocker  United States
those last two will be tough without a schematic... they are reference designators, not component names or values, the first I can't say off the top of my head.
If this device didn't die from a short-circuit on the output, you may want to find out the "other" reason it went south before spending too much time on it.
note: high-res. pictures ususally help.
Jesus loves you.
Old 22nd December 2004, 01:52 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi skiermurph,
Okay, you have a 2SC3423 that is bad. Sounds like one channel of a stereo amp. So, you have another channel that is working and you can trace from there. DO NOT swap parts between the two channels. If you do you will have two dead channels in short order.
Look at the other channel and how the parts are hooked up. This should give you a clue. Now .... if someone has a schematic.
-Chris
+/-15v dc stepdown for novice Learnincurve Power Supplies 10 3rd December 2007 07:46 PM
Could anyone help a novice? sunnycue Full Range 8 4th August 2006 05:45 AM
DAC question from a novice fishwinker Digital Source 6 17th June 2006 07:41 AM
Novice Schematics dalcorn Class D 4 24th July 2005 09:12 AM
reg psu q - stupid (novice!) lazyfly Chip Amps 14 10th September 2004 01:44 PM
Page generated in 0.06175 seconds (73.26% PHP - 26.74% MySQL) with 10 queries
