Old 23rd December 2004, 04:39 AM   #11
hangguy is offline hangguy  United States
Okay, this is weird. I ohmed out the diode bridges and all eight diodes measured fine. Using a DMM, in one direction it's open, one direction it's measuring ~40ohm.
Then, measured all 4 main PS caps, there is no problem as well. They are charging up nicely.
So what else could be wrong? What can give me a 160V AC on my B+ rail for both channels? This is with no load on the B+ and B- rails at all.
Mike
Old 23rd December 2004, 05:53 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Mike,
Bad connection with your meter, or there is something wrong with your meter. A high level AC across a cap would draw huge current, heat the cap and pop the seal.
Take your time and make sure you have a good ground to the meter, then retake your measurements. While you are at it, measure the RCA jack gnd potential and spkr gnd potential. If you are careful then measure the emitters of the diff pairs. They should run around 0.6V from ground as the bases are ground referenced.
-Chris
Old 23rd December 2004, 07:41 PM   #13
Hi Chris,
Yes, I agree this doesn't make much sense. Too bad I don't have an oscilloscope to look at what is really going on.
I am borrowing a good DMM from work and will verify the readings and take some more tonight. All previous readings have been referencing to Power ground (center tap of the transformer secondary). Will try to measure the secondary output, and poking around more in there.
Mike
Old 23rd December 2004, 08:06 PM   #14
anatech's Avatar
Hi Mike,
Take your ground reference from a "quiet" ground point. Somewhere on the chassis is normally okay. Probably easier for you too.
As far as meters go, I find that Fluke models are the best. They also hold their calibration better than most. For bench meters, an HP is hard to beat. (I used to work in a calibration lab). A Fluke 87 series is one of the few handheld meters I will trust much over 60Hz on AC. Whatever the current Fluke 87 is called.
-Chris
Old 24th December 2004, 08:09 PM   #15
Yep, it was a bad meter. Using the borrowed Fluke meter, everything looks normal, no AC at all on the rail buses. Signal ground is sitting at about 0.2V for both channels.
I will go make more in depth measurements tonight.
Thanks to all for all the suggestions. Merry Christmas and Happy New Year.
Mike
Calling all Rek-O-Kut Experts ! ! ! Bamalama Analogue Source 3 4th March 2009 02:43 PM
Calling all Soundstream experts chemhaz Car Audio 4 29th April 2008 02:01 AM
Calling all ATC mid experts! TwangBar Multi-Way 6 21st April 2007 02:13 AM
Calling all Heatsink Experts! vsr123 Pass Labs 3 28th August 2003 10:21 AM
Page generated in 0.09380 seconds (72.46% PHP - 27.54% MySQL) with 11 queries
