It's complete no feed back . It have some new ameliorate . The old type I had build more , tomorrow I'll build this.
#2 |
It have protect circuit .But the power supply is another board.
#3 | |
- will you share your sonic impressions with us? - also, FFT diagram may be interesting (in particular, harmonics lowering speed), - what is done for thermal stability? - what PS voltage and bjt models do you use? Thanks! |
#4 |
don't you think that a cap parallel to diodes in DCservo is redundant? and may couse troubles? i would use a resistor in there.
#5 |
Electrons are yellow and more is better!
This cap is a major part in the servo, can't be removed. This input filter make sure the gain is constantly dropping instead of landing at 1, because this is an non-inverting integrator.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
I would be concerned about thermal runaway (thermal bias compensation), but other than that, it's interesting.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good. |
#7 |
I have made the amplifier, with output stage wich you can see, 4 years ago. It sounds very good.
#8 |
About POST #4 said the cap, I'm very agree POST #5 said, this cap with the resistance organize a filter, the filter touch the sound,
Today, i've complete the board and tset it . |
#9 |
audio-gd,
Nice amplifier units! Looks proff., nice and tidy. A lot of power devices for this kind of heat sinks, though,.. I think. My thought is that it's over-kill (but then again, isn't that what DIY is all about?) with the power transistor's power handling capabilities, compared to the heat sink's size. Jennice
#10 |
This cooler weight about 2KG, and I'll put it on the amplifier both sides ,then it can cool faster. I think it can deal the family use.
But this is a cheapness edition to my Hi-END amplifer XA-100. In XA-100, the cooler is weight about 10KG, and the circuitry is quite complex . But the cheapness edition can use simple circuitry and keep the sound good. It's circutry I'd ameliorate time after time . Send the XA-100 picture under. |
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.12411 seconds (71.55% PHP - 28.45% MySQL) with 11 queries |
