#31 |
In the amplifier , it can work in well without compensate capacitance , the capacitance's capability can change the tone color ,so it can choice 0-33P .
#32 | |
#33 |
The power supply
#34 | |
#35 |
The voltage is +-30V to +-60V , it can work well, if change some parts , it can use higher voltage
#36 | |
What is each output stage transistor quiescent current value? |
#37 |
About the quiescent current value ,It's different value will have different sound.
In my model amplifier ,the each output stage transistor quiescent current value is 75MA, total is 300MA. I've this PCB, only need $8.75 (2pcs, stereo board , without postage.) |
#38 |
audio-gd,you are Hi-Fi DIY Master!
Best Wish to you!
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
