Old 20th December 2004, 12:44 PM   #1
Default Transformer – shield wiring
I have a transformer with a shield between primary and secondary. What is the correct way to connect the shield?. To the audio ground or earth ground? There is no connection between both grounds in the unit.
Jarek
Old 20th December 2004, 12:49 PM   #2
Mr Evil is offline Mr Evil  United Kingdom
Connect it to earth.
https://mrevil.asvachin.eu/
Old 20th December 2004, 01:38 PM   #3
Connect it to earth
Due to safety issues or sonic preferences?
Jarek
Old 20th December 2004, 01:40 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I thought there should be a loopbreaker circuit or similar in between.
Old 20th December 2004, 02:45 PM   #5
Both. If the shield were connected to circuit ground instead, a fault in the transformer could cause the internal circuitry to float at a high voltage, which could be dangerous. If it's earthed, then a fault should blow a fuse, alerting you to the problem.
Also if the shield is connected to circuit ground but not earth, then noise currents could be coupled into the circuit more easily.
There have been many discussions on best earthing practice here before. As long as the case is earthed (if it's metal) and everything else is insulated well from live parts, then you don't have to connect earth to circuit ground, although personally I almost always do, just for piece of mind and to prevent problems making connections to earthed equipment when the power is on.
Old 20th December 2004, 05:52 PM   #6
Thanks Mr Evil
Jarek
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
How to shield a transformer? Wynand Everything Else 9 12th January 2007 10:05 PM
transformer shield newbie q torzsok Chip Amps 19 29th September 2006 08:29 PM
How to connect electrostatic shield of power transformer? bee696 Tubes / Valves 4 23rd July 2005 10:54 PM
Transformer Wiring? Killjoy99 Parts 4 2nd October 2004 11:00 PM
Page generated in 0.08866 seconds (77.24% PHP - 22.76% MySQL) with 10 queries
