Old 19th December 2004, 07:14 AM   #1
tman is offline tman  United States
Default Please Help with ADCOM GFA-555 II
Hi everyone,
I'm new to this forum and to audio electronics. I just picked up a Adcom GFA-555 II that is in need of repair. I will try to explain the known problems best I can given my limited experience.
Problem: Left channel does not work. Blowing the negative fuse on the left channel. (the fuse that has a "-" above it. Also, when checking the transistors on the power board protected by that fuse my rusults are 19ohms on the top three and 0 ohms on the bottom transistor (labeled Toshiba 2SB554).
Also, a resistor located on the audio board (R114) is giving me a reading of roughly 100ohms. That resistor's mate for the right channel (the side that is working) R164 is reading at 300 ohms.
Just wondering if I'm in the ballpark with this or not as far as figuring out what problem may be causing the left channel to blow fuses.
I would appreciate any comments whatsoever. Thanks for your time,
tim
PS I can post pics if anyone is intersted is seeing the suspected components.
Old 19th December 2004, 11:37 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi tman,
Welcome to the forum!
There are other threads on the forum with information on this model. It seems you will be replacing a matched set of outputs and drivers and possibly predrivers. Not a terrible job. Do it right and the unit will last for years to come. You will likely find some burned resistors.
So, take your time and don't buy the cheapest parts. Use On-Semi parts where possible - real ones. There is lots of help here, but do a search and read the previous posts.
-Chris
Old 20th December 2004, 08:29 PM   #3
K-amps is offline K-amps  United States
K-amps's Avatar
Tim,
I have the original Toshiba replacements for the 555/ 555II. I upgraded many 555's to MJ21195/96's so I have many Toshiba's I pulled out.
Send me a self addressed envelope, I will send you a 554.
Cheers!
K-amps.
PS: Will buy that 555II off you if you don't want to repair it... or even exchange with a working 555. ;-)
Old 20th December 2004, 10:23 PM   #4
anatech's Avatar
MJ15022 / MJ15023 or MJ15024/MJ15025 will work fine for outputs as well. You must change all the outputs in the bad channel.
-Chris
Old 20th December 2004, 10:36 PM   #5
K-amps's Avatar
-Chris
"Must"..... ok I will keep shut. ;-)
Old 20th December 2004, 11:51 PM   #6
Thanks for the info everyone,
I would be more than glad to pay you for the part. Just let me know. By the way, I found this amp which looks brand new for $50 dollars. I hope I can repair it myself but I will keep you in mind if I can't. Part of the reason I'm trying this is to learn more about electronics. The more I read on this forum, the more I realize how much I need to learn. Oh well, guess that is part of the fun of a hoppy.
Thanks,
tim
Old 21st December 2004, 02:03 AM   #7
anatech's Avatar
Hi K-amps,
Yup, must.
It really isn't worth losing more parts to one transistor that tested okay with a diode test. Over 25 yrs experience to prove this.
Remember, parts are way cheaper than speakers and a tech's time to do it again.
-Chris
Old 21st December 2004, 02:36 AM   #8
K-amps's Avatar
Anatech,
I use a 100 watt bulb in series... yet to lose an amp on power on....
Happy Holidays.
Hey Tim,
I have roughly 20-30 pairs of original 555 output pairs from Toshiba, let me know how many you want. Email me with details.
Old 21st December 2004, 11:56 PM   #9
Default Hey k-amp
Hey Kamp,
I could not retrieve your email.
If you see this message, please email me.
Thanks again,
Tim
Old 22nd December 2004, 01:21 AM   #10
K-amps's Avatar
just emailed u my prodigy email
Adcom GFA-565 sourceoneaudio Solid State 11 13th July 2011 12:43 PM
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 03:42 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 10:20 AM
Adcom 2A IC for GFA 565 CompNut Solid State 18 2nd February 2007 06:16 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 08:09 PM
Page generated in 0.11794 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
